I have been fighting and actively troubleshooting this since September and I am getting tired of it. My battery is dying in 2 days if my Pathfinder is not driven. As long as I drive it once every 24-36 hours it will be fine, but as it approaches 36-48 hours, it is noticeably weaker. Once it passes that 48 hour mark it is basically dead and if it hasn't been driven at all in 48 hours, the keyless entry, lights, etc. don't even work.
If I drive it every day, it will run just fine and start just fine every single time. I did so for 3 weeks straight, until I needed to use my pickup for a few days. Came back and of course, the Pathfinder was dead...
I have taken it on 200+ mile road trips and it will do fine. The battery only dies when the Pathfinder is not being driven.
Here is what I have tried:
- Testing battery - passed (Battery is new as of March
- Testing alternator - passed (Alternator is new this year and is OEM)
- Replaced alternator with another new one under warranty - no change
- Replaced battery - no change
Found THIS post from forever ago. Chuck (rest his soul) had some good things to try as he always did, and so did ARKQX33V6. I read through that thread and a few others, and followed some troubleshooting tips in them:
- Disconnected negative terminal and watched sparks - lots of sparks so something is pulling some amps - duh
- Disconnected positive terminal and connected a multi-meter set for amperes. Started pulling fuses to check for amp drop when problem fuse was found. I pulled every fuse and relay I could find and no drop in amps...
I have LED headlights and HID foglights as well as an aftermarket Clarion head unit and a PAC audio interface. I also have some off-road driving lights haphazardly wired in. I have no sub or extra amp or anything like that.
- I tore out all of the wiring for the off-road lights because it needs redone properly anyway - no change
- I unplugged both foglights - no change
- I unplugged both headlights - no change
- I unplugged all HVAC controls and Stereo equipment - no change
I swapped the interior lights to LEDs a couple years ago (you know.. for the horsepower
I have read a little bit about the starter being the culprit by drawing too much current at startup and then the truck not being driven enough to charge the battery back up, but it seems more like a bad ground somewhere to me. Also, my commute is nearly 30 miles one way highway so I would think that is plenty of high speed time for the alternator to charge the battery.
I am out of ideas, and opening myself up to any suggestions people may have.
