ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu Dec 09, 2010 1:05 pm
Battery age makes a difference, but...
You must start with a known full charge battery tested after a full charge with a battery hydrometer to test the electrolyte in each cell at 1.25 or higher S.G. If battery is maintenance free cut off the 3 cell cover and inspect the electrolyte charge and level.
With the battery test and known good, hook up in the car with clean terminals, no grease. A helper may be needed.
With a cold engine, and with a voltmeter at 20 VDC, read the meter as the motor is started. Read the meter as the motor fast idles, read the meter as the idle comes down to normal and fin ally read the meter as the RPM is upped to 2500.
Expected readings:
After recharging the battery and testing with an hydrometer must have 12.7 V
No hydrometer get one, battery terminal voltage at least 12.7VDC
While starting cold motor and battery hooked up, during starting or cranking no less than 10 VDC.
At cold higher idle at least 13V to 13.5
At warm engine 750 idle at around 13.25
At 2500 RPM at full voltage of 15 VDC
If all is good, shut the engine.
With a good multimeter set to 10 A maximum for Amps and test leads correctly placed on meter, with one lead as common and one lead at the amps 10A whole. Remove the + lead from the battery with all the wires/cables. Clean the battery + terminal and the + lead that you disconnected.
With the car off, all lights off hook the meter probes one to the + terminal of the battery and one to the + wire/cable that you removed.
Read the meter in Amps. record this number and tell us.
Expectations:
An off engine and all off car will still draw some power. Power is needed for:
The alarm system
The main computer or controller
The radio for presets and clock
And anything aftermarket.
Remember that an automotive battery when depleted 20% is considered dead. Voltage of 11V is a dead battery as far as delivering any amps. A new battery at 400 CCA at 11V will not deliver this same CCA.
If the battery is not charged enough it will not deliver its amps.
Depending on the age of your car, the starter may also be suspect.
Winter is a killer, At 0C, 32 F a new battery is about 20-30 % depleted just being in the cold and the colder it is the worse it gets.
So start your testing with a known good battery.
