07wHiTE 3.5SE 6sPD wrote:all those control boxes that are located in the interior arent they plastic? How would it ground on something that cannot conduct electricity. And if the box is outside and constructed of metal 99 percent sure its grounded. And if his power wire melted and is actually grounding off, it would create a load that will blow the fuse before causing any damage (assuming it is a fused power wire)
This is spot on. I think I read in the Droptoberfest thread that you were only running 2 600 watt amps? I really dont think thats enough power to fry a 4 gauge wire unless there were some serious wiring issues. I still would like to know where this control box is, I would think it would be somewhere down the centerline of the car and there is no reason said shop should have run a power wire that way, it would be more time consuming and tedious for them to install. Plus fuse issue, if it did contact the metal on this control box the fuse should have popped immediately. If this shop didnt install a fuse within 2 feet of the battery they shouldnt be in the business.
Either way, someone is full of it. Dealership taking nonsense or install shop with heads up rears. Sucks man...good luck.
