Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Feb 09, 2004 3:46 pm
Did a little test today 90Q,50F, 36k remanned transmission trimode TCU, JWT ecu other systems oem stock. Set up consult to log parameters during a 1st to 2nd gear shift...........time in 100th of seconds, data updated every 0.02 seconds:
01.76 seconds: 7,000 rpms, MAF 4.38 volts, 9.5ms, 26 degrees02.03 seconds: 6,510 rpms, MAF 4.36 volts, 10.2ms, 26 degrees02.05 seconds: 6,465 rpms, MAF 4.35 volts, 10.0ms, 16 degrees*02.07 seconds: 5,125 rpms, MAF 4.34 volts, 10.2ms, 07 degrees
02.50 seconds: 4,530 rpms, MAF 4.11 volts, 11.0ms, 03 degrees02.58 seconds: 4,400 rpms, MAF 4.02 volts, 10.8ms, ZERO deg02.60 seconds: 4,300 rpms, MAF 3.99 volts, 10.7ms, 04 degrees
02.62 seconds: 4,420 rpms, MAF 3.96 volts, 10.6ms, 20 degrees*
02.76 seconds: 4,500 rpms, MAF 4.02 volts, 10.6ms, 21 degrees
03.21 seconds: 4,650 rpms, MAF 4.06 volts, 10.8ms, 23 degrees
The ignition cut for torque management was 0.58-0.60 seconds total.The total shift from peak rpm [7,000 rpm] to the time ignition advance returned [4300 rpm] was 0.80 seconds.
BY the way the VVT stayed in the 8 deg overlap condition.
Unfortunately the speed function is not up dated fast enough or the wheels were spinning as 44 mph occured at 1.04 seconds into the record and 54 mph occurred at 2.50 seconds and 57 mph occured at 3.21 seconds.The speed did not change during the shift period
Now I have to find a bad transmission to record similar data
