1999 Q45 transmission leak
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
I have a leak somewhere on my transmission
when I drive and stop the car I leave a couple drops of transmission fluid on the ground at the back where the driveshaft comes out of the transmission
initially I thought it was the rubber seal where the shaft coems out leaking but when the car is in the air and I wipe it clean and drive it back around the leak isnt coming from there. The fluid is primarily over the bunch of sensors underneath the end of the transmission (turbine revolution sensor harness and those other plugs)
soooo... where else is the leak coming from? I cant see where it is coming down the side of the transmission from the top but it is a bit tight up there
any help? any ideas?
thanks!
96Qowner
Car: 1996 Q45
It's probably coming from the turbine revolution sensor, a not-rare issue with Y33s.
zerothread?id=204402
There are two ways to get at it - drop the transmission or bore a hole in the floor.
Modified by 96Qowner at 12:02 PM 7/17/2007
Q451990
There are two revolution sensors on the transmission, at least on the G50. One on the front end for input, and one on the rear to measure output. With these leaks being near the back, I would suspect one of those first...
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Yes, but if it is leaking from the connectors on the driver's side, which are toward the rear, then it can be verified by tracing the fluid that it is the turbine revolution sensor.
Modified by maxnix at 4:28 AM 7/19/2007
qship96
Car: 1996 Infiniti Q45
If it is leaking just a few drop per day WHO CARES! let it ! I would wait til transmission needs to be dropped for other reasons and correct it then-not worth the hassle or expense to drop transmission to stop a few drops on the pavement! All older cars ooze !!!!!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
qship96 wrote:All older cars ooze !!!!!
Mine don't, but I the bad turbine snesor. I remember Q45tech said something about transmission wear increasing if the turbine speed sensor is not sending the correct data. But it would be best to read his post as I am fuzzy on the details.
When you do repair it, be sure to replace the engine's rear main seal as it is inexpensive and you will have done all the labor.
qship96
Brian,your cars are just reaching puberty! all less than 100k right? My q is approaching 195k,no drops on floor,but visible wetness on transmission connectors-will take care of when trans needs to come out for another reason--like replacement!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The one that failed had about 30K on it and had been flushed. Shocks also leaked by 45K. Has about 60K now.
