Oxford. F&W is German, they probably won't burn easily.
Steevano101 wrote: ↑Sun Sep 03, 2023 7:20 pm.. The vacuum intake line to the IACV was completely plugged. I cleared it out and it seems to take longer before the pressure drops and the IACV does start working after it warms up and you increase rpm. ..
Maybe you're right. When and why did you replace the fuel pump?Steevano101 wrote: ↑Mon Aug 07, 2023 3:31 pmReplaced the hose and drove it with a fuel pressure gauge hooked up. A mile down the road fuel pressure started dropping from 42 until it died. I could put it in neutral while still rolling and start it back up and fuel pressure would go back up to 42 and shortly start dropping again. I'm going to replace the filter and see if that makes a difference. If it doesn't, does that mean the new fuel pump is bad or could it be the fuel pressure reg?
Nope. That's the EGR valve, which is shown in the picture I posted with an arrow indicating where the IACV is located.Steevano101 wrote: ↑Mon Sep 04, 2023 3:26 pmAren't there 2 hoses on the IACV, one goes to the manifold and one the box at the rear?
I'm kinda thinking you might be right.
Did replacing the relay have any effect?Steevano101 wrote: ↑Fri Sep 01, 2023 10:34 pm.. Going to pick up a new relay tomorrow. If that doesn't fix it, ..
Could be part of it and might have been all of it until your friend messed with it. If the idle adjustments were randomly tweaked to drop the idle, you need to get it back to the proper adjustment settings. Check out the Basic Service Procedures for Fast Idle Cam, Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment starting on page EC-34 of the factory service manual. https://www.nicoclub.com/service-manual ... 8%2Fec.pdf Get this back to "...started first try, ran great, had plenty of power, life was good" before your your "mechanic" got hold of it. If you get it back to just having an idle up around 1000rpm and just the P0505 code, read up on the IACV-AAC valve starting on page EC-323 to see how you can test it, clean it, replace it, or fix any wiring issue that may be ailing it.Steevano101 wrote: ↑Thu Sep 14, 2023 4:41 pmCould all this be related to a Bad IACV or should I just find a cliff and give it a Push?
