d.bright »
https://forums.nicoclub.com/d-bright-u196224.html
Mon Mar 12, 2012 3:07 am
Well more good news. The rough idle and white smoke seems to have been caused by a combination of the MAF sensor and bad fuel. I took the connector off for the MAF sensor and I noticed it seemed a little loose, I pinched the metal connectors and it made a big difference. The white smoke eventually stopped coming out of the tailpipe, I think it had to do with either bad fuel that was sitting for a month, water condensation in the tail pipe, or both. Anyways, I called my Grandmother and found out that she was using 87 octane instead of premium, so the first change I get it's getting filled up with premium.
The other good news is that the transmission seems to be fine, it was about 2 1/2 quarts low on fluid. I topped it off, and it shifts into D without any problems now, so that's a huge relief. I'm going to drop the pan and change the filter this coming weekend just to be safe.
I was able to take it for a spin around the neighborhood, and it's like night and day how it drives now compared to before doing the under plenum job, it's very responsive and has some good get up and go to it.
There are only two problems left, and they may in fact be related:
1. The CEL is on but I can't pull any codes from the car, it might be my scanner (I'm using Android Torque App w/ Bluetooth OBD/II scanner), I'm wondering if this has happened to anyone, and if there is a way to get a blinking code output from the car?
2. The fuel pump seems to be on its last leg, when I turn the key and the fuel system pressurizes, it sounds like a cordless drill that is running out of power. And when I turn on the car it makes a constant humming sound. With my experience working on other cars this usually indicates the pump is about to go, and sometimes this means that there isn't enough fuel pressure either. Is this the case with this car too? I'm wondering if the engine isn't getting enough fuel sometimes and that's what causes the CEL to come on.
Regardless, I couldn't be happier, I'm pretty sure I'll drive her for a while now since the transmission seems to be fine. I just wish the driver seat went down lower, I feel like I'm propped up somehow and I'm 6'3 so my legs hit against the steering wheel when I try to use the parking brake, I have to open the door to use it.
As soon as I finish detailing the interior and get it washed, I'll post some pics.
Cheers!
