1996 Maxima knock sensor
regent4
Car: maxima 1996 & 2005
Had a P0325 code and purchased a new knock sensor. I tried to follow the knock sensor online tutorial but found the EGRC solenoid (with the green connector) gets in the way of sticking your hand into the engine cavity in the 1996 models. I tried to remove the mounting nut for the EGRC solenoid but there is not room for my wenches or sockets to remove the nut. Removing the bracket the EGRC solenoid is mounted to is not a good option. I hate to have to pay $400 to have this repaired. In searching for help I found a Knock Sensor Relocation kit for the 1990-96 300ZX.http://www.yugobernie.com/techs/Det_Sensor/
Would it be possible to do the same on the Maxima? The cost of the knock sensor and the sub harness (PN 24078-30P00) would be much less than a dealer repair.
maxhopper
Car: 02 Maxima SE 6spd
I would imagine it's possible, I just don't know how well it would work.
turbocat
Car: 1998 Maxima
I have a 98 maxima, i changed out the knock sensor in July, the way i did it was, to remove the top of the airbox and the plastic air intake tube, then i got about 2 to 2.5 feet of extensions and put a swivel on the end then the socket, and i got the bolt to break loose on the top of the knock sensor, my max had just 1 wire going to the knock sensor. hope this helps.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Here is a thread on how to replace the KS. There is another link within the thread (motorvate) that shows images of the KS.
zerothread?id=148066
Here's a YouTube posting by "boredmder" which should also help you replace the KS.
4th4Lyfe
Car: 1999 Nissan Maxima SE
Those things are a beast to change.
Presscott707
Car: 1999 Maxima 5spd
4th4Lyfe wrote:Those things are a beast to change.
there not all that hard bro i did mine in around 20 to 30 mins. it just matters on how big you hand is, or if you do it the long way and take off the upper intake manifold.
