GseaQ »
https://forums.nicoclub.com/gseaq-u329.html
Wed Nov 09, 2011 1:02 am
Update - no, not fixed. I've been using the bikes all summer, so haven't moved the Q. I did tinker with her a bit off and on when I had time.
I replaced the fuel filter.
I replaced the spark plugs. They all looked OK for mixture but they were OLD. I didn't put them in as I had thought, so God knows how old they are. One strange thing, though. #6 gap was only 0.6mm instead of 1.1mm. After I ran the new plugs for about 20 kms, I pulled #6 and checked the gap - still at the 1mm as when installed. Weird. BUT, the plug colour was WHITE. Pulled #4 and it was also WHITE. Granted, that's only 20 kms, so I'll check them again tomorrow.
I removed the IAAC valve again and cleaned it with spray intake cleaner and a brush - now like new. I then used a full can of Seafoam Intake Cleaner sprayed into the intake hose behind the MAF. Just before that I took the hose off and used a spray Intake cleaner, rags and elbow grease to get the Throttle Body good and clean.
The result? No change. In fact, it seems worse now than I remember, but that could be my imagination. I had to get it Aircared (smog test) today for licensing. It passed - barely. The numbers seem to indicate it is running lean (just a guess). Here are the numbers from the smog driving cycle tests done December '08 & 149,000 miles followed by today's #'s at 178,000 miles.
Then - Hydrocarbons (HC g/km): Max Allowed - 0.5, my car - 0.0992, Average for this model car - 0.1352
Now - Hydrocarbons (HC g/km): Max Allowed - 0.5, my car - 0.4470, Average for this model car - 0.1419
Then - Carbon Monoxide (CO g/km): Max Allow - 9.32, my car - 1.6233, Average for this model - 2.9640
Now - Carbon Monoxide (CO g/km): Max Allow - 9.32, my car - 5.0413, Average for this model - 4.8305
Then - Oxides of Nitrogen (NOx g/km): Max Allow - 1.24, my car - 0.2354, Average for model - 0.3798
Now - Oxides of Nitrogen (NOx g/km): Max Allow - 1.24, my car - 0.0680, Average for model - 0.2160
As you can see, there is a big difference in the numbers from when the car ran fantastic 3 years ago and running like s*** now.
I'm back to suspecting the fuel pump now. It was supposed to have been replaced by the previous owner before he shipped the car to me (I paid Infiniti of Scotsdale to send one to him), but given how crooked he was, I have no faith it got replaced. If it was replaced, it can't have more than 40,000 miles on it.
Can you guys (Mike, you suspected the fuel pump in the beginning) review this whole thing again, please, and post your thoughts? Do my symptoms fit a failing fuel pump? Is it possible it finally got to the point way back that it just was not supplying enough fuel or pressure? Could the smooth cold running have been (it doesn't even run smooth when cold now) due to the pump running faster when cold (because of the FPCU)? Maybe when warm and loaded by a slight uphill grade at low revs, not enough fuel, nor would there be enough fuel at WOT, thus creating the spitting and lower power. Finally, will a failing fuel pump cause a rough idle, stumble and rough take-off from a stop and bucking under slight low RPM load?
Not knowing if the pump was replaced 40,000 miles ago or not, I'd like some encouragement before buying another one. Time's up, I need to get this sorted out fast now that winter is here.
Thanks,
Glenn
