ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Tue Mar 06, 2007 5:55 pm
And the only things chicks seem to dig more than the new corvettes is the classic camaros and mustangs. Honestly, I think a Ford V8 is the best option for swapping American muscle into the Q. They have front sump oil pans and can make big hp very easily. Use a basic '87-92 mustang 302 and you get forged pistons and roller cam from the factory. Add some GT40 or aftermarket heads with a good cam and headers, and 400hp is cake. Use a 351W and you can easily stroke it to 427" for far less $$$ than the LS1. You can also bolt a T56 to it. The LS1 is GMs new ford small block. That sounds screwed up, but with evenly spaced intake and exhaust ports, oil pump in the front, same firing order as the 351 and 302 H.O., and 1.7 ratio rockers, it sure sounds like a Ford small block V8 to me. It's what Ford should have made instead of the 5.4L OHC. The Q is too heavy to be a fast car without sinking lots of money and effort into it. By the time to build the power to easily beat M5s (especially the new V10 E60) with the stroker LS1 in the Q, you may as well just start with a smaller and lighter car. If you were to use a 351 ford with inexpensive 4r70w auto trans from a '99+ V6 mustang (uses the old V8 ford bellhousing pattern and has strong internals, just needs shift kit and converter), you could probably build a 450hp 351 and have a trans that will hold the power with .67 overdrive and lockup converter for under $4000. With $1000 more you can build a cast crank 427 that will make 500-550 streetable hp. I don't know much about LS1 stroker kits, but I believe a 4" stroke crankshaft is right around $2000. Add rods and pistons which are likely about $1200 and then all the machining and balancing, and it'll add up quick. A cheap 351W stroker kit is to use stock 351W rods (good to 600+hp), 302 pistons (factory forged would be fine), and a cast aftermarket crankshaft (about $400) which gives 393". There's plenty of ways to go about it. I still think a remote mounted turbo is the way to go for a goal of 400hp. If you want 500+hp and gobs of low end torque, a big inch american motor would be best.
