check your ecu malfunction codes. remove sparkplugs and check to see if cylinder are wet. take the injectors out and see if they are leaking fuel.I dont think it is wise to unplug something when it is receiving power. the arc is going to damage the terminals at the very least.HSVDrifting wrote:there was no change when I unplugged my maf or my o2 sensor...though when I plugged the maf back in while the car was running, it died. I haven't checked the injectors yet...cause I'm not sure how.
Did that. It's showing 11, 13, and 34. I've not been able to find a list of ECU codes for my year motor...and I'm not sure if the codes are the same for like the 95-98. Assuming they are, that's (respectively): Camshaft Position Sensor, Coolant Temp. Sensor, and Knock Sensor. (according to: http://www.240sx.org/faq/artic...h.htm).vancouverbc wrote:check your ecu malfunction codes.
I haven't checked the cylinders, thought I have pulled the plugs and they were covered with quite a bit of carbon, and if I remember correctly, I think one or two times, the plug was a little wet. The exhaust is almost always wet, however.vancouverbc wrote:remove sparkplugs and check to see if cylinder are wet.
I'll try that shortly.vancouverbc wrote:take the injectors out and see if they are leaking fuel.
I didn't unplug while the car was running. I unplugged it and then started the car. I plugged it back in after the car had been running and it just shut off.vancouverbc wrote:I dont think it is wise to unplug something when it is receiving power. the arc is going to damage the terminals at the very least.
This right here makes it sound like if the distributor timing is off...then so is fuel injection...couldn't this, in conjunction with the missing coolant sensor, cause the car to run hella rich?1991-94 240SX FSM wrote:The crankshaft position sensor is a basic component of the entire ECCS. It monitors engine speed and piston position and sends signals to the ECM to control fuel injection, ignition timing and other functions.
The crankshaft position sensor sends signals to the ECU to control fuel injection, ignition timing and other functions. Check the harness connector and check the engine ground that's near the temperature sensors.HSVDrifting wrote:The guys at Nissan told me that since the ECU wasn't seeing a signal, it was thinking that the motor wasn't warming up so it was trying to give it more gas to warm it up...which makes sense. Anyway, I got the sensor and installed it, as well as wired up the knock sensor. I wiped the codes, as you suggested and gave it another try...got 55 this time. When I tried to start the car, then checked the ECU codes it was throwing 11 again. I'm assuming that the Crankshaft Position Sensor code is just telling me that my ignition timing is off. I need to get hold of a proper crankshaft pulley so I can time it effectively.
One of the guys in the Nissan Parts Department here was telling me that I shouldn't use a timing light, but that I should use a vacuum gauge. I don't really understand this. Can anyone shed some more light? If I could somehow get this thing timed right...I'd be SO happy...
Thanks,Collin
I don't mean to come off like a smart ***....but I know what it does. Where it's located is what I'm not 100% sure about. If I'm not mistaken, it's located in the distributor, correct?rogoman wrote:The crankshaft position sensor sends signals to the ECU to control fuel injection, ignition timing and other functions.
You mean make sure all the wires are still good? It'd also be helpful (methinks) to know which wires do what. If it's the plug I'm thinking that it is, (the 4-wire one side of the distributor) then I can't imagine what the 4th wire is for. I'm sure there's a power, a ground, and a signal wire...but the 4th? I guess I could be totally off and it could be somewhere else...but I seem to remember that that's what the slots in the plate inside the distributor are for and that they opperate off of an LED and a Photo Diode.rogoman wrote:Check the harness connector...
You mean the one that looks like it's supposed to connect to a valve cover bolt, right?rogoman wrote:...and check the engine ground that's near the temperature sensors.
I plan on it...but I can't get it to idle or even run right so that I can do that.rogoman wrote:By all means use a timing light for the ignition timing.
Yes, it's in the distributor. The harness connector is under the base of the distributor body.HSVDrifting wrote:I don't mean to come off like a smart ***....but I know what it does. Where it's located is what I'm not 100% sure about. If I'm not mistaken, it's located in the distributor, correct?
