Didderson »
https://forums.nicoclub.com/didderson-u38557.html
Sun Oct 29, 2006 1:16 pm
Well, she was running about 2 weeks ago, then I took the 240sx to valvoline and got the fuel injector cleaner and engine kleen flush service done. After this, idle improved immediately, but when i tried to start it up the next day, the fuel pump had died. I replaced it and the car still won't run. It'll crank over and sputter and ALMOST start but it wont finish. I'm going to check the fuel pressure soon, but I'm suspecting a clogged injector or four because prior to getting the car running it had been sitting for more than a year. Either clogged injectors or a malfunctional Fuel pressure regulator? I've replaced the fuel filter also.Any thoughts/concerns appreciated! Thanks in advance.
