w0lfatncsu »
https://forums.nicoclub.com/w0lfatncsu-u31138.html
Sun Oct 22, 2006 1:07 pm
Okay, I was driving my car to work a few days ago (96 240SX, stock) and as I was pulling away from a stop light, I shifted into second and the car bogged and after I pushed in the clutch, the engine cut off. I coasted into a lot, towed it home, and went to work on it that night. I got it fired up again, even moved the car under it's own power, but after a few minutes, the problem came back. At this point, it's an utter PITA to get the car cranked, I have to adjust the distributor and even then it usually tries to turn over and eventually fires up. Once it's cranked, it idles without a problem. As soon as I goose it though, it bogs down and gets close to cutting back off. I'm stumped at this point and I'm just trying to figure out where I should go from here. It's throwing no CEL at all by the way, and the last time I had it idling I broke out the timing light and had everything set back in order. So, in summary, it's taking forever to crank and once it's running, it's fine unless I sharply rev. I can ease on the gas and it revs fine. I pulled the valve cover, set the engine to TDC, and the cam lobes for the #1 cylinder are both pointed outward, which I've been led to believe is how things are supposed to be. I'm at a loss right now as to what the problem may be.
Here's some pictures showing how my cams are sitting at the moment.
