1991 q45 5 speed z32 transmission wiring help!
MANSU_V36
Car: g35s sedan
240sx s13
rx7 fc3s
ive searched ever where but i cant find anything. can someone please post a link or PDF file of the wiring i must do to get it started. thanks in advance :biggrin:
2brokey
Car: 1995 Infiniti Q45 - The Daily Beast
1994 Volvo 940 Turbo - Storage Unit?
1993 Nissan 240sx SE Fastback - Toy with big plans...
1992 BMW 325i Convertible - Needs to go to body shop...
Usually to get it started, you would need to bypass the inhibiter switch. I haven't done it on a Q yet, but I've done it on many 240sx's, a Mazda MX-6, and an Integra. If you have the FSM, it will help you alot. Usually the main things you need are to close the loop for the inhibiter switch circuit (because as you know the inhibiter switch makes it so it only starts in Park or Neutral), and find the wire for the back-up light switch (you should be able to trace that off the AT harness). Good luck! I'm sure somebody has it in a write-up somewhere, and if not, someone else should be able to chime in with exact details.
subtle_driver
Car: 1989 240sx hatchback, 1990 Q45 5-speed, 1973 Datsun 240z, 1987 Starion Turbo, 2003 Subaru wrx, 1995 Infiniti q45 5-speed,
installing-a-5-speed-into-my-q45-t480074-60.html check out my 5-speed thread from last year. there is some useful info there and pictures. worked for me! been driving the crap out of my setup for a long time so it must be good info.
