Infinitiguy19 wrote:I mean no disrespect because you did a beautiful job but some of the things you did do not add horse power.
According to some of the old posts In read from NICO removing the OEM exhaust or any part of it and adding the loudest exhaust known to man will only leave you with a 10 HP Max gain.
Changing the OEM air intake design will only cost you horsepower (HP) in the real world, Dyno's are not a measurement of true power. The cone filters allow air that is heated by the engine to pass through it. Where as the OEM design is the best designed Cold Air Intake I have ever seen. Seriously take the cover that covers the hood latch and windshield washer fluid container. Its in the center of the two headlight covers.
The OEM clutch fan was very efficient and only cost a couple of horse power Max though the RPM band. at Sixty nine hundred RPMs the OEM cltuch fan costs you 3 HP. But adding a electric fan only shifts where the power drag comes from and that is the alternator. So a electric fan will only do one useful thing which is allow you more space to work in that area.
E-Mance, The company is worse than useless and I hope bad things happen to the owner. I would get rid of that tune and put a real performance tune in like a NICO ECU.
Removing the cats is also useless as they were designed for the most performance while doing their job correctly.
Again I mean no disrespect but at the same time I didn't know if you knew this or not.
Thank you for your information, I didn't know this, and apparently the car and the dyno doesn't either.
If you want to race with your stock intake and stock fan and stock exhaust with the cat's let me know. I'm running E-mance tune in my car and I LOVE IT! I ran E-mance tunes for 4 years without a problem.
On average, removing cats on many v8 vehicles frees up anywhere from 8ish, to 30ish hp on a stock motor. from what I've seen in person.
Let's see how much more power the VH45DE will make when I remove the cats shall we?
According to your post reading, and my real-world experience you are going to be surprised. BTW, did The Infiniti Indy car team use catalytic converters on their Indy car?
BTW, Can you show me a dyno sheet that shows the 3hp increase from the fan removal?
When the stock fan is in full lock what happens to your power?
When my 4,500 CFM electric fan is off, when I'm drag racing, or Autocrossing, or Drifting it doesn't rob any power from the Alternator drag. Only when I'm stuck in traffic with the A/C on full blast does the fan turn on.
I also Love my Jim wolf pop-charger! The stock air box is not to my liking, I want to suck all that hot air into my engine! For some reason, it makes more power that way. I guess I'll keep it. I have seen many factory air filters make more power than the cone filters and intakes, but this one doesn't. I know what it looks like, I removed the ram air tubes long ago to make room for my transmission cooler.
Too bad the Automatic Factory transmission is so heavy and slows the car down so much. I had to remove that and install a more efficient manual transmission. and a stronger and lighter once piece drive-shaft. I guess the factory isn't thinking about performance all the time, they may be thinking about cost and comfort. Think about the 2nd gear start, is that an efficient design from the Infiniti Engineers? I hate to say this, but my car is ugly when i look at it sometimes, But I love the surprised looks on mustang driver and Bmw drivers when I pass them up. I think this car is not perfect, but I still love it!
I'm glad I never listened to the naysayers and know-it-alls on this forum. Even tho my modifications are not to your liking, at least I'm giving you some entertainment, you can point and say, "you're doing it wrong" all you want. LOL!
BTW, do you think its possible to make 400hp and 500 ft lbs of tq at the crank with a stock internal ka24de from a 240sx with 200,000 miles? We'll my friends at e-mance helped me make this possible. And I spent less than $1,500 on the total project including the car. I guess I should stop using Cone filters and removing the cats.
http://sdclubracing.com/index.php?optio ... =19&id=458
