Carl H wrote:and why not?
agressively modified setup...big turbo...I am going to asume he's trying to make some reasonably big power on this setup.how else would you monitor ignition timing?
The differences ignition timing has an effect on tempature isnt going to be picked up unless the user is going to datalog all EGT readings or the tune is retarded off... its not a huge difference to see... there is no target EGT to reach... its not a diesel
Ignition timing is just a number, doesnt matter if its 10 degrees or 50, you should be watching maximum brake torque on the dyno and checking spark plugs religiously thats the only real way to see whats going on.. tuning an engine via EGT is pointless unless you have 6 EGTS and a way to log it...
Not all cylinders run at the same tempature with the same AFR and Timing either so how accurate could it be unless you had one for each cylinder...
ninja edit.. Also more likely then not EGTs are hot from lack of timing and to much fuel which isnt going to hurt the motor, maybe wear on the oil and turbo faster but its certinally not going to blow up...
Now the other way around (lots of timing and or lean mixture) will blow the motor, but you should be using other things to determine which is occuring
