Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Oct 09, 2002 12:07 pm
On the transmission cooler issue... the theory behind bypassing the "cooler" in the radiator is that it's not really a cooler (that's the reason for the quotes). If I recall correctly, the transmission is designed to run at an optimal temperature of about 160F, but the engine runs at a much warmer temperature. On hot days the coolant in the radiator will be hotter than the ATF flowing through the A/T "cooler" in the radiator tank, so you're actually heating the fluid.
If you live in a very cold climate, the heating effect is a good thing, since overheating isn't really a concern and you want the transmission to warm up to the optimal temperature range. Here in the south, I don't see temperatures much below 20F, and now that she's always garaged, it should probably never get below 40.
The B&M external cooler has an orafice that supposedly works off of the ATF viscosity that will keep cold fluid from flowing through the cooler (sending it directly back to the A/T) until it warms up. I assume this works. Also, by using Mobil 1 ATF, the viscosity of the fluid is more stable, so warm-up isn't as critical.
I'd say with the Mobil 1/ B&M Cooler setup you'd be safe down to 15 or 20F. If you anticipate colder situations and not a lot of really hot stop and go driving (below 90-95F), I'd run them in series. I've also thought of putting in gate valves, so you could switch from the external cooler to the factory "cooler" with the various season, but it's probably not necessary here...
As for the transmission heating up, remember that it's bolted to the engine, and aluminum is a great heat conductor. The heat from the engine has a good path to the transmission, not to mention the two exhaust tubes with catalytic converters running beside it.
Sorry for the book, but maybe this helps clairify things...
Heath
