cccpman »
https://forums.nicoclub.com/cccpman-u36612.html
Sat Oct 13, 2007 3:28 pm
I think what you are asking is if you can just plug and play a replacement, the answer is yes. The TCU (transmission control unit) is what causes the car to start in second, your going to need something like a 93 (93-96 right?) TCU to force it to start in first. It is in pretty good demand, the secret is to pull it from a junked Q and that will save you even more money then the generous folks here at NICO in most cases (supply and demand usually here)
BTW I think the first start could actually help extend the life of your transmission somewhat, starting in first should help keep down on the heat right? (dont quote me on it, read it somewhere around here )
