Searching for parts for this car. Need to replace the entire rear end. Car is a t-top hatchback. Any help or ideas? My boss is very sad to have damaged the rear end.
Check the 300zx Classifieds section on this site and on Twinturbo.net for used parts. Also check local junkyards, ebay and craigslist for z32 parts. You can also post up some pictures so we can see the damage
When you say rear end... what exactly are you talking about? Body damage? Suspension? Frame? Or all of it? Really depends on what you need to replace in order to find the right stuff. For example... if you have a ton of rear structure damage... you might be better off buying a non running shell and cutting everything off that you need. Suspension and axle parts you can find in junkyards or online used.
Postby
Paulcanta »
https://forums.nicoclub.com/paulcanta-u209815.htmlWed Sep 19, 2012 4:42 am
Thanks to all responses. I will take some pictures and post. I am a "newbie" so this might take a while. The car was in an accident and the entire back end was "crumbled".
