thank you for your comments! the lean afrs are due to tuning not the Walbero fuel pump, thank you.the 255lph walbero can do over 450 on e85. more on 91octane gas. I will go back when i have some time, and acually tune the car and see what numbers i get. Like i said, that was one of the runs i pulled off vacuum lines after the maf to artificially raise the afr's, and it worked. haha. i need to get the other dyno sheets with the normal afr's. but it would mean i would have to drive an hour to do that. im lazy and broke.Q45tech wrote:Something is wrong with your dynojet graph as it does not follow the multi-hundreds I've seen especially in the torque presentation below 4,000 rpm.
Good luck on your modifications. Carefull about removing or recalibrating the fuel damper reference hose [after MAF] as this is a very necessary item to stablize the fuel pulses around and above 4,000 rpm.
Your AF chart varies significantly and is extremely lean for any power gains probably the result of Walboro.
What was tire roller interface temperature before and after runs? Tire brand, size, and psi to derive a frictional correction factor.
The rub is a chassis dyno accelerated faster than possible on street due to mass difference in roller and lack of air friction.
When you reach 14.8/98 mph in a sea level quarter mile with stock diff you know you have reached nirvanna.
Over 8 years here I've seen lots of dyno runs very few are accurate presentations of what is really occuring, but it gives some something to talk about.
All in all I like quarter mile tickets better as they are significantly more reliable [unless substitution occurs].
If you really want to "thinky thinky", read Q45tech's earlier posts on this and other subjects.1QIKQ45 wrote:... HMMM.. Thinky thinky thinky
I have been reading up on all of the old posts.Now i know that all of you are WAY ahead of me in knowledge, but i just find it hard to believe that Nissan made the intake for the VH Perfect for the amout of air it needs to breath.And even if they did do that, when you start upgrading the exhaust, ECU, fuel, then the intake most deffinatly wont be able to flow what the new mod's need. Nothing is perfect, there is always somebody/ something out there beter, faster, stronger, Ect.So if you ran a 90mm+ intake tube, perfectly smooth on the inside, that slowly grows in size as it get lower to the ground, allowing a bigger space for the air to "ram" into, then y wouldnt that function beter than the factory?Not that i dont believe you guys, but the OP has a graph that shows increase in HP and he says all he did was remove the Air box, and i believe him.A pixture is worth a 1000 words.maxnix wrote:If you really want to "thinky thinky", read Q45tech's earlier posts on this and other subjects.
You need to read more.1QIKQ45 wrote:I have been reading up on all of the old posts.
Thats what i meant. Lower to the ground meaning into the path of larger amounts of colder air. Im not saying that the increase will be astronomical, it just seams that there would have to be benifets of some form. (other than sound)maxnix wrote:the distance of the intake from the ground has nothing to do with inlet pressure. Locating it in a high pressure area does.
In both directions with a stabilized engine temperature, you might get an indication.1QIKQ45 wrote:Ok then, Find someone who is as close to perfectly consistant as possible and have him run 10 pass's down the 1320?5 with a stock box and 5 with a cold air?
i like your sig....Trumpkin wrote:You have struck a nerve here with all the "big boys". They all have proven this before-long before you got here. Or so they say. best to leave it alone! You are rocking their forum!
Back to the 100 bidirectional timed runs!Q45tech wrote:* First personal Q dyno runs were in 1993 thats when I learned different 15" rear tires can change numbers by more than 10 HP due to wear index.160 vs 340.
so true!Q45tech wrote:
If things make you happy why not. My Q LIVES on the mistakes of others [junker parts].
Yes, experience is an education earned dearly!elwesso wrote:
so true!
