1990 240sx water leak
bobbdude
water leaking out the back of the head, is there a water line back there or is it the gasket even with mirror can't see, can't get to it. i've searched all past topics. thanks for any help.
NY S13 SR
Probably the heater core hose or the turbo coolent line, both are on the back of the head / block. Find a kid or girl with small hands to help you, it's not fun fixing those things......
_____________________Jeff HHeavy Throttle Performance Inchttp://www.heavythrottle.com
bobbdude
it's not the head gasket I can see with a mirror there is no water lines in that area
bobbdude
car is for sale!!!!!
ramal
Car: 1992 nissan 240sx convertable
you may want to check the freeze plug. There is one located right at the back of the head. I had one pop out after the engine overheated and it took me for ever to figure this out..
leroiboy
Car: 1989 Nissan 240SX Coupe
bobbdude wrote:car is for sale!!!!!
if this is an s13 sr20det, let me buy the ecu please...let me know
Hijacker
Car: '92 240sx Convertible
'94 F-150
Take all sales and inquiries to the for sale/want to buy forums please.
oki_bum
Car: SR Powered 1990 240SX
back of the head? like between the firewall and motor? There is a coolant line that runs to your turbo from there. Mine was leaking. I had to pull the motor to replace the hose.
bobbdude
there is not a turbo on this engine, it must be a freeze plug. how do you get to that. after i stop the car you can hear water boiling but the gauge shows normal and it doesn't seem like its running hot.
sicairos_2007
Car: 3 Nissan 240 Sx
you have a bad heater hose
bobbdude
I checked heater hoses there not runing behind the engine, it's a 4 cyl. has anyone pulled the head on one of these 2.4 and is there a freeze plug on the back side of the head? I can feel it driping above the head gasket.
ramal
zer...47218#http://forums.nicoclub.com/zer...8#Yes there are 2 freeze plugs right on the back of the head. Its all most impossible to get to them but if you can get the leaking one out you can replace it with a rubber adjustable one.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
bobbdude wrote:I checked heater hoses there not runing behind the engine, it's a 4 cyl. has anyone pulled the head on one of these 2.4 and is there a freeze plug on the back side of the head? I can feel it driping above the head gasket.
this doesnt belong in this part of the forum
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
i think he has a KA, not an SR.
since you dont have a pressure tester for the cooling system, just insert a garden hose into the radiator, hold it tight, and blast water through it. besides the radiator fill hole, you'll see water gushing through other leaks in the system.
