neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Thu Sep 07, 2006 10:24 am
just measure your stock box or you can be lazy and eyeball it. Another route would be to take your air filter in the junk yard with you, and get a box that is bigger and has a larger filter slot. IIRC probably dont so, anyways a taurus or crown vic and the vic box is pretty big and the bottom side is gutted from factory (ram style) snorkle that draws air from in front of the rad. btw the stock box is decent to mod just not big as the engine could use. It flows with the stock paper filter just enough air. But anything to help the engine breath easier is an improvement. Another secret I will let out is mod the factory air box that is in the fenderwell,under the stock filter box. Cut it out with a dremel or something so that it acts like a scoop to put cooler air into the filter box.
