I need to pass MD's very strict emissions, so these lines need to be ran perfect for when it goes into the shop.
Please don't reply "you don't need that ish" or anything silly like that.
The line on top is connected between the vacuum motor on the intake pipe that leads out to the front of the vehicle and the ATC temp sensor. The other line just hangs from the temp sensor and was broken. The last one goes to an open hole inside the air cleaner area just below the temp sensor, as shown in the photo:
What should the two that are broken be connected to and where is said device located please?
