1981 720 4x4 SD22 build
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Master-O-Turbonics
Car: 2004 Nissan Frontier CC SB
1981 Datsun 720 4x4 SB
1981 Datsun B310 2 door sedan race car
So I just bought this 720 standard cab short bed 4x4 the other day.
just before surgery this morning(mind you I'm by myself doing this, lol):
yanked the motor:
pulled the cab:
pressure washed for a couple hours:
front clip from a 720 with all the gear for the SD22 engine... going to be interesting getting the pan to clear the front diff....
fastboatman29212
Car: left this forum. Sold my truck.
Wow! Welcome to NICO 720s. Is there anything you CAN'T do?
Master-O-Turbonics
fastboatman29212 wrote:Wow! Welcome to NICO 720s. Is there anything you CAN'T do?
I try to do everything....
BTW this truck has around 290,000 miles on it.
fastboatman29212
What plans do you have for the truck? Your post makes me think you will put the diesel engine in the truck, but how well does it run?
Master-O-Turbonics
The diesel motor runs great. I fired it up on the front clip and ran it for a while. just needs some new coolant hoses.
PEZi
Very nice man! Welcome!
JoeCool6972
Car: 2017 Infiniti QX50
COOL! Keep updating. :bigthumb:
Master-O-Turbonics
Got the bed off this morning and started cleaning up the frame rails... spent 13 hours today grinding and cutting off bed mounts.
Had 2 gallons of high gloss red paint donated to my cause, and 2 gallons of high gloss black as well as epoxy primer and all the other stuff I'll need to paint this thing.
Where I quit today:
Master-O-Turbonics
Made some progress on cleaning up the frame today. spent a couple hours grinding.
definitely a lot of work but it's getting there... hopefully going to hit it with epoxy primer this weekend.
N-Dually
Car: 1986 Nissan 720 Dually
Awesome! Keep us posted!
woodbutcher5691
Car: 85 720 2wd 5sp.
3- 280zx's
Sweet!
I wish I had 1/2 the time and 1/3 of the shop you have, I hate you. :poke:. Keep us updated, looks like a good start :yesnod .
woodbutcher5691
3- 280zx's
BTW where do y'all race at? Looks like you have several toys to play with. :cool:
Master-O-Turbonics
Its a 10,000 square foot shop... pretty nice.
We race ARCA so we basically follow wherever NASCAR goes. We run anything from 2005 Cup cars with 2007 bodywork all the way up to 2010 Roush Nationwide cars.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
sick, I wish I could find a SD22 around here. I've seen a few but they belong to old guys who love them.
Master-O-Turbonics
finished pulling crap off the frame today
The stock open 4.375 R180 differential(would be great for autocross or lower speed road racing courses for a 240Z, probably going into my parts collection)
a bit more progress and a peek into our fab shop
Also found and ordered an old Nissan manual on rebuilding/shimming the transfer case... Old Nissan manuals like that are hard to find.
breadbox
89 Koop
84 720 4x4KC
I wish I had the much indoor room to work.
Keep it up mang.
woodbutcher5691
3- 280zx's
Yea, mang.
You prolly puttin' pin stripes on it by now. Let us SEE! ;)
Master-O-Turbonics
Haven't really made any progress on the truck since the last post, but I did get the factory transfer case manual in.
breadbox
89 Koop
84 720 4x4KC
oooh transfer case overhaul. Got a scanner? :naughty:
Master-O-Turbonics
more work done today
flipped the frame over and did more grinding/ cutting off the IFS
Test fit the diesel motor and looks like motor mounts are 1 3/4" further forward than the gas motor, so I'll be doing those next time I get to work on the truck...
Master-O-Turbonics
Acquired a decently built Hi-steer Waggy Dana 44 with aussie locker.
(wheel has too much backspace and hits the stock steering arm, hence the funky camber)
GOTTA get the motor mounts done!
Master-O-Turbonics
Picked this 1971 521 up to donate the body onto the 4x4 truck. :-D
breadbox
89 Koop
84 720 4x4KC
:mike This is turning into a seriously badass truck. :badger Rock on man. Amazing work.
Master-O-Turbonics
Ground on this frame until I killed all of my Grinding discs.
Donor truck trying to hide from the carnage around the corner...
Master-O-Turbonics
Finally got the frame rails cleaned up and ready for motor mounts
breadbox
89 Koop
84 720 4x4KC
:biggrin:
Everytime I see an update I feel like I am not doing enough.
Keep it up man. I love this whole concept. I really would like this finished product. :yesnod*
*I know ratsun feels the same. (I am Zombro there, In case I comment on your stuff there) I check both places but usually post here first.
Master-O-Turbonics
This morning came in and finished up a couple little spots and started laying Epoxy primer.
Then I started laying color
I still have to do all the front suspension mounting, but the majority of the chassis is done and will just have to do touchup on the areas to be welded.
Master-O-Turbonics
I decided on a paint scheme... and it is the same scheme I had on my 260Z, but never finished it and it was just Rustoleum...and I may paint the hood red.
Got a pinstriper who is going to do some silver pinstripe between the two colors as well.
Old school pics from 2006 of my gutted and LOUD 260Z
Ratsun jackstands:
Nathyne
Car: 1994 Skyline GTR
1983 Datsun 720 4x4 reg cab KA24E swap in the works
Wow makes what I am doing look like childs play. Can't believe how much progress you're making. Want to see this thing running!
Master-O-Turbonics
Started sanding some today with an air powered DA sander and 180 grit just to find out how BAD the roof damage is (farm truck, carried ladders leaning against the roof)
Looks like it should all be able to be filled in and re-contour'd with finishing putty. Going to apply seam sealer in the drip rails since the factory sealer is long gone.
Hit it with some flat black just to keep it from flash rusting.
Return to “Datsun 720”
