Did some firewall work this morning... mounted the 720 steering shaft... solidly... and got the brake setup at least mocked up.
Need a new clutch master cylinder for a 521... I have a feeling this is going to be hard to find?? Maybe a regular Datsun one will work cause they are like $15 at Napa.
Did what I call a karate chop to the fenders. I think it looks pretty fricking cool, and at the same time it keeps the stock lines of the truck.
I made the cut, rolled the cut outward just like the stock little flare with the English Wheel, then bent a lip back under just like stock, but now it goes straight forward. Not perfect, but a skim coat of finishing bondo will help smooth out the small divots.
Going to cut away the lower turn signals and core support up to the bottom of the head light buckets for tire clearance...
UNDENIABLE:
