kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Fri Jun 04, 2010 10:23 am
That heat shield is on my hit list too, I hate it, it rattles like crazy and this past winter got bent and consequently on a long road trip would intermittently rattle against the exhaust or frame like crazy, it hurt our ears and it was a nightmare trip. I bent it back into place with my fingers, it's very flimsy and not secured well at the end. I've considered hacking the end off but before I do I'll have Nissan check that all he welds are in tact at my next visit this month.
There isn't anything you can tighten on that heat shield, it's welded in place, although like I said the leading edge towards the front of the vehicle can get bent and need to be bent back. I'd let them have a look and see if one of the welds broke, but be ware it could get noisy on a highway trip. If this happens, just look under the vehicle, you can see it and reach it with your hand without jacking the car up (if a weld is broke, this won't help however). If it's bent, i.e not parallel front/back, you can easily straighten it out. Not a great solution but if you're on a road trip and the noise is driving you nuts, you'll be wanting to try whaterver you can to shut the noise up! Good luck.
