centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Fri Aug 19, 2016 1:12 pm
So, to clarify, you have the housings, but those did not come with the actual bulb holding sockets that plug into the back of those housings? I'm a little bit surprised/ disappointed that the housings you bought didn't come with those. Have you tried the turn signal bulb sockets from your OEM setup to see if they fit? You could also try the corner lamp sockets I think. Then pull the same from a junk yard or online, rewire the pigtails...
