turtle240 »
https://forums.nicoclub.com/turtle240-u130942.html
Fri Mar 12, 2010 11:27 am
now as you all know USDM turn signals only have 1 bulb and socket and the JDM 180sx CHUKI turn signal has 2 bulbs and sockets
im going to take you through (step by step) how to wire your USDM turn signal harness to the JDM amber/clear turn signals
first the wiring diagramSolid Green Wire (running light)Green w/ Yellow Stripe Wire (blinker circuit)Black Wire (ground)Red Wire (power-running light)
here is the USDM signal
here is the JDM signal (i used the D-Max signals instead of the amber/clear signals)
the first step is find a socket that will fit the position light hole (the smaller hole) for this i used the side marker sockets from a 93 altima
now cut and strip the solid green wire on the stock bulb, and the red wire on the smaller socket
the green wire that goes to bulb will not be use so you can cap that off
now you can connect the red wire to the solid green wire that goes to the harness plug
you can now splice the black wire on the smaller bulb into the black wire on the USDM harness
then wrap it in electrical tape to prevent moisture from getting in and the end product should look like this
now you can install it on the car!!!!
RUNNING LIGHTS
4-WAYS ON
CONGRATS you are JDM TYTE YO!!!!
