+1.yokota180sx wrote:+15 +12dont be a pansy and do it
I WAS a pansy, and went 17x9F +35, with a 15mm spacer, and 255 rt615s, and 17x10R +35 with 275 rt615s. the fronts rubbed the coils without the spacer, but the rears didnt. I'm running stock alignment in the rear which is like .5 *, roll and pull, and I havve the 275 tucked, with room to spare. I will probably get a spacer and add some camber. optimal in my opinion, now at least, for the best fit with minimum issues and no crazy alignment, 17x10 +25 R, 17x9 +15 F, roll and pull. +12 is easy too, just a lot of camber and a stretch tire. I'm running 275s in the back for the track.
