bigdaddychia wrote: Yes this is the convential auto transmission. Fluid changed every 30k with synthetic oil. Oil changes also using synthetic every 7k to 10k miles I have done one brake job fronts at 96k rears at 146k and plugs at 100k. Been through 4 sets of tires. And found the cheapest place for an air filter is the dealer. go figure
Any advantage to using synthetic fluids over conventional ones? Have you used synthetics for your other cars before? Just want to know if it's worth paying that much if it works for you.
