17 inch wheels on a 94 q45
WesAllen
I am thinking about putting 17inch wheels on my 94q, but am concerned about any possible negative results of doing so.
Could those knowledgeable in these types of things please give me some advice.
Thank you in advance
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
17s with 245/45/17 or 255/45/17 (I think) seem to be about golden for 94 Q...... Although, 16in seem to be about the best for Q..... 17s are a good choice though....
Be careful when buying rims..... If you get cheapo ones, they will bend very easily, as most arent designed for the Qs weight......
If you get them from http://www.tirerack.com , be sure to use the links given here, as you get discounts..... Plus, all the rims they mention on their website will meet or exceed all OEM load capacaties and stuff like that......
I personally would recommend getting some infiniti take off rims..... I personally like the new Q rims or the G35 rims......
Just make sure whatever rims you decide to get, you have good tires to match it......!
Welcome to NICO.....!
WesAllen
Thanks you for your quick reply and also for your welcome to these forums
PalmerWMD
Car: 2004 350Z
17 inch work well o a Q45.
Many feel 18's are too much.
Also there is good selection in performance tires for 17's.
Fred...:)
PalmerWMD
Car: 2004 350Z
Also:
A very popular wheel among the congnoscenti are the 16x8 rear wheels of the early 90 Nissan 300ZXTT, Very strong + good round out specs.
Its easy to accomplsih a wheel tire combo of good load rating with those wheels.
Also many cutsomers of new Infinitis get custom wheels put on so many dealers have in stock so-called take-off's:OEM wheels that will be much cheaper than usualy yet still comply to teh tough regs of an OEM wheel..
Fred..:)
elwesso
2007 BMW M Coupe
:Werd
Does anyone have a pic of the 16x8 Z rim..... I dont believe ive seen what those look like........!!!!!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:Does anyone have a pic of the 16x8 Z rim..... I dont believe ive seen what those look like........!!!!!!
Look just like all the wheels on the 1990-1996 300ZX. Rear TT wheels are an inch wider, so 1/2" more rim to the outside of the wheel.
Rex
Car: None
Is this them???
Rex
Car: None
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
That is indeed one. Left front, I think. Looks like they were driven through rocks with no tires, though.__________________Brian1995 Q45 & Q45t & 2000 Q45
Discover the power of the button!
elwesso
2007 BMW M Coupe
Those chromed would probably look pretty good on a Q.......
Rex
Car: None
I have 245/45/17's on mine. They and the rims were on it when I got it. If I had to do it all over again, I might, might go 16's, but from what I've seen posted here it may be harder to get 16's with the "correct" load rating.
If you're on a limited budget, spend the same money on 16's rather than trying to queak 17's into the same budget. Better rims (lighter stronger) are the best thing, regardless of size.
elwesso
2007 BMW M Coupe
What kind of 17s do you have on your Q.... Well, I guess Ill see the 18th..... :D
Rex
Car: None
:( I don't know what they are, trust me I've looked for any markings that would help me figure out, and posted this pic before to see if anyone would recognize, but no luck.
http://www.nissaninfiniticlub....23150
And yes you should see it next Saturday :)
See my Q in Member's Rides to see some '01 Q45 16" rims with 255/50ZR16's on a 95Q.
szh
Car: 2018 Tesla Model 3.
AZhitman wrote:See my Q in Member's Rides to see some '01 Q45 16" rims with 255/50ZR16's on a 95Q.
And my Q in Member's rides to see some G35 Coupe 17" rims with 245/45ZR17's - also on a 95Q.
Z
russg
szhosain wrote:And my Q in Member's rides to see some G35 Coupe 17" rims with 245/45ZR17's - also on a 95Q.
Z
OK, I give up. I can't find the "member's rides" area mentioned. Little help please?
Russ
PalmerWMD
Car: 2004 350Z
russg wrote:OK, I give up. I can't find the "member's rides" area
check this sticky:http://www.nissaninfiniticlub....38751
Fred..:)
Q45tech
Don't be surprised that most used even oem wheels are out of spec as they only were designed to last 60k in average driving.The uglier/thicker the better..........the current trend towards prettiness has significant downsides.
Same with lighter duty G35 wheels the weight and camber take their toll when used on Q.
Measure a few early Q t 15" wheels - these FULLY forged unit are still perfect after all these years........but they ain't pretty.
Rex
Car: None
I'd suggest trying to find some 10th anniversary take off's. Big (fat) 5 spoke 17's.
russg
Rex wrote:I'd suggest trying to find some 10th anniversary take off's. Big (fat) 5 spoke 17's.
These are nice looking wheels. I had them on my Anniversary Q. However, you should probably acquire them with caution. There was a factory recall on these wheels. Anybody know how to tell the good ones from the bad?
Russ
Rex
Car: None
As always consistently valuable information found on this site :)
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I think Infiniti is replacing all of them produced between certain dates.__________________Brian1995 Q45 & Q45t & 2000 Q45
russg
At the time I bought my 94 Q new, the factory Q wheels were pretty ugly, in my opinion. I didn't want to go aftermarket, so I opted for a set of J30 chromed take-offs. Probably not the way to go today, but it seemed like a good idea at the time. Never saw another Q done that way. Sorry for the poor quality of the pic. A scan from a beat up photo.
PalmerWMD
Car: 2004 350Z
Doesnt look bad.
Hey Russ are you gonna upload soem M45 pics in our memebrs ride section?
Fred..:)
russg
PalmerWMD wrote:Doesnt look bad.
Fred..:)
I'd be happy to. Mine are all shot at 2048 X 1536 native resolution. What rez do you recommend me cutting them down to before posting?
Russ
PalmerWMD
Car: 2004 350Z
Your guess is as good as mine..:oface
You can always edit your posts/pics and play around with it until you like the results best.
Fred...:)
PalmerWMD
Car: 2004 350Z
If you photo exceeds approved dimensions it will automatically resize them to max approved size.
Fred...:)
russg
Fred..:)
'Tis done.
Russ
PalmerWMD
Car: 2004 350Z
Looks great!!
Fred..:)
