Fred...
Welcome Wes. My 2 cents: I have a 94 Q with 245/40/18-18x7.5 rims. There is minimal affect in ride, increase in handling. Only problem is that in messed up cities like NY you have to slalom like a olympic skier from the craters they call potholes. I have driven long distance from NY to ATL and the ride is still great due to the wonderful, ahead of it's time suspension. 17's would be great for you. Minimal but reasonable change in ride, but makes for a better looking vehicle. I could never understand why dealers used to place a two ton car on 15's. That's like a sumo wrestler on ice skates! They're learning though:thinkerWesAllen wrote:I am thinking about putting 17inch wheels on my 94q, but am concerned about any possible negative results of doing so.
Could those knowledgeable in these types of things please give me some advice.
Thank you in advance
You can always flip them side to side, just like you would have to do with directional tire or wheel. Of ocurse, as Q45tech has stated so often, most of the stress on a Q45 is on the front anyway, so you do want to match the highest load carrying capacity there anyway.Jeff Williams wrote: I rotate every month (5,000 miles), and this extends the life of the tires, but if I don't keep the same size tires all the way around, I will not be able to do this.
Your car is hot Jeff. Hot color!Jeff Williams wrote:WesAllen, welcome.
I have a 1994 Q. I bought some 17" rims (Konig Diva)off of eBay, and have put several sets of different tires on the car.
I started out with a set of used Bridgestone Potenza RE92 225/50/17. The load rating was not rated for the Q, but the tires worked great. They are expensive.
Then I went to a set of used Contonental Sport Contact 245/45/17. Was not happy with ride quality. The inner sidewals are actually softer, and is not good for the camber of the Q. Burned up the set REALLY fast.
The third set was a set of new NITTO NT455 225/50/17. Directional tread was a little noisier, and the load rating is still a little light for the Q. Great tire wear, much longer than expected. Great wet and dry traction. Tires needed to be balanced every rotation. Great price.
The set I have now, is Sumitomo HTR+ 255/45/17 on the rear (just bought), and 2 of the NITTO's on the front.The tires are just the right width in the rear (requires an 8" wheel), but I am torn whether to keep the narrower tire up front. I rotate every month (5,000 miles), and this extends the life of the tires, but if I don't keep the same size tires all the way around, I will not be able to do this. I will probably stick with the same size all the way around
My car is stock ride height, and stock struts. I plant to install the Eibach springs and Tokiko Blue's, this winter.
I hope this helps.
I have al ink in my signature for a photo albumn of my car.
THANKS! I thinks so, too. I am truely blessed to be driving such a nice car.OLU40 wrote:Your car is hot Jeff. Hot color!
Jeff Williams wrote:In the back of my mind, I want to get my hands on some 18" M45 polished aluminum or chrome plated wheels.
NY94J30 wrote:It seems Infiniti has a tendency to go narrow - J is 15 x6 OEM - for the sake of EPA mpg ratings.
On a brighter note, I just upgraded to 17 x 8 (235/45/17 Falken Ziex)
I am sure yours are from burnouts. Mine do too, but not for the same reason. I typically do not drive hard in the corners, and with the Independent Rear Suspension, the camber is set a little negative for hard cornering. When the car goes into the corner, the inside suspension extends, and the camber goes neutral, and the outside suspension contracts, making the camber neutral, as well. If the car does not do much hard cornering, the inside edge of the tires gets more wear. I spend 99% of my driving on the interstate, and that is why I had to replace 2 tires, and will replace the other 2 in a month, in my opinion.Jesda wrote:The front gets a harder workout? Hmm. From my experience the rears get chewed up very quickly.
-Jesda
J-Spec Tuner wrote:what do you guys think of these, there are a ton of them on ebay.
http://cgi.ebay.com/ebaymotors...43958
szhosain wrote:Replica wheels for that price would be of great concern - I certainly would not buy them. I would much rather get G35 wheels or M45 wheels to fit the Q - they do show up occasionally on eBay. The size of this replica is the same as the OEM M45 size, by the way.
Z
