rb25crazy wrote:i just saw these rims on ebay and i'm liking them and especially the price. my question is will they clear z32 brakes and i'm guessing they already clear coilovers with that low offset. i was also wondering if anyone would know they'd look on a kouki s14 like how much it'll stick out? or will it be flush etc...
http://cgi.ebay.com/ebaymotors...74690
thanks! i tried searching but no dice.
http://www.1010tires.com/WheelOffsetCalculator.asp
Hey look at that, i had almost the same question. I currently have been looking for wheels and fitment topics for my s13 240sx. Still trying to learn a few things here and there. I found these same Sportmax 002 16x8 w/0mm and the 15x8 w/15mm wheels and was wondering the same thing. Well according to the Offset calculator:
OEM S13 7 spoke: 15x6 w/40mm offset
15x8 w/15mmInner Clearance: THE SAME (the inside of the wheel to the strut housing)Outer Position: EXTEND an extra 50mm (position of the outside edge of the wheel)
16x8 w/0mmInner Clearance: 15mm MORE (the inside of the wheel to the strut housing)Outer Position: EXTEND an extra 65mm (position of the outside edge of the wheel)
Now from this information, this means that the 15x8s will fit fine on the inside but extend out an extra 50mm when compare to the OEM wheels. Correct me if i am wrong with any of this as i am also learning more & more about wheels, fitment, etc. The extra 50mm shouldnt be a problem if the correct suspension height and tire combo is used. Right?
Also from this info, the 16x8s should fit but a 15mm spacer is required to achieve correct fitment? Or is it that they'll be 15mm further away from the strut? Then that would mean that NO spacer is required and theyll just stick out more? If i use a spacer, wont that push the wheel further away from the strut? Also these wheels will stick out an additional 65mm in comparison with the OEM wheels. Suspension and tire combo will play a role aswell.
... I've heard good about these wheels even though at first i didnt think too well of them. They are pretty cheap and the manufacturer Sportmax doesnt seem like a well known brand, im a firm believer of "you get what you pay for" but this is so cheap that i wouldnt mind picking up a set to start off with. To me, they seem like a decent set of wheels and when matched with a nice set of sticky sports tires would get the job done, atleast as my first wheel upgrade. Im mostly concerned with grip and by no means an experienced driver. I know how to drive but still a novice driver. Sorry to thread jack dude but id figured id ask for the both of us and others wondering about the Sportmaxs and or these issues. Oh btw i plan on using Q45 front calipers/brakes and OEM rear brakes all with their own corresponding brake pads.
Heres the models i like:
501
002
Modified by davidricardo86 at 7:30 PM 12/26/2006
