It's great to have fun, but you can certainly look like a fool if you push your luck. I've been there and done it many times myself. Luckily I have gotten away without serious injury.Juelze wrote:Well, so far so good until I got hung up in some deep snow. AWD works well IF the wheels are on the ground. Luckily, some people helped me shovel the snow from underneath my car and I was on my way...
Not sure what is meant by this statement?Importroller wrote:at least the snow will keep your CVT cool, so it can actually work properly.
I think he means that you can keep the AWD locked longer as it will turn off if the sensor reads a certain temp. Anyway, I'll have to disagree with you a bit kerrton. While I agree with some of your sentiments, there is no way my Rogue would have made it through the snow that I had if it was a FWD Rogue with good snow tires. If your front tires get stuck or start spinning, having the rear wheels kick in will save your butt.kerrton wrote:Not sure what is meant by this statement?Importroller wrote:at least the snow will keep your CVT cool, so it can actually work properly.
Anyway, your performance in snow will be most affected by your tires. It doesn't matter how good the AWD system is, if you have bad tires you're in trouble - I'd take a FWD Rogue with good winter tires over an AWD with stock all-season tires. In my opinion, AWD is highly overrated in vehicles other than trucks. In trucks you're comparing AWD to RWD, so it is a real benefit to be able to add the front wheels to assist with traction, but in a vehicle like the Rogue where the base model is FWD I think there is little value in adding AWD. In my experience, it makes people overconfident and dangerous in a lot of cases, but that depends on the individual driver.
I've never had this problem. Even when towing in hot 90+F temps.Importroller wrote:My statement is that the CVT is known for overheating, and the cold snow will help keep the temps down so that the transmission will work properly.
Well, Kerrton does have a point...Anyway, I'll have to disagree with you a bit kerrton. While I agree with some of your sentiments, there is no way my Rogue would have made it through the snow that I had if it was a FWD Rogue with good snow tires.
I still have to disagree. If you had a FWD Rogue with snow tires versus my Rogue with AWD and all-season tires, you'd be stuck and I'd still be driving by you. I've been driving FWD vehicles for years in snowy conditions, and trust me, they would have all been stuck if they dared set foot...er...tire...in the recent snow storm.philipa_240sx wrote:I've never had this problem. Even when towing in hot 90+F temps.Importroller wrote:My statement is that the CVT is known for overheating, and the cold snow will help keep the temps down so that the transmission will work properly.
AWD is great for acceleration, but this does not equal grip. The grip available is determined by the tire's 4 contact patches alone and not how many wheels are being driven by the engine.
A similar FWD Rogue equipped with 4 proper snow tires will stop faster, corner better, and be far easier to drive in slippery conditions than an AWD Rogue with all season tires. You don't get into accidents accelerating off a stop light (at least not normally)... it's stopping for the light or negotiating a corner that will get you into far more trouble!
Regardless what you drive, please be safe out there! If the weather is bad, just stay home rather than risk your life.
Juelze, strangely, Philip, Kerrton and I have all a FWD Rogue, and all of us put snow tires on during winter. BTW, we all live UP NORTH, a place called Canada.Juelze wrote:I still have to disagree. If you had a FWD Rogue with snow tires versus my Rogue with AWD and all-season tires, you'd be stuck and I'd still be driving by you. I've been driving FWD vehicles for years in snowy conditions, and trust me, they would have all been stuck if they dared set foot...er...tire...in the recent snow storm.
Now that's nice. I really wish they'd do that up here in Alaska. It drives me crazy when I see someone doing 10 under the speed limit on a clear day with clear roads because they don't have snow tires.Pescakl1 wrote:Also, for the last 3 years, Quebec made it mandatory that every car and truck to have winter tires from Dec 15 to Mar 15.
I am a big advocate of winter/snow tires. Partly through many years of driving in poor winter conditions... I travel on average 30,000mi per year. I was also active in motorsports for several years. Tires have a huge impact on the handling of any vehicle. Using the right ones for the conditions can make an incredible difference.philipa_240sx wrote:The grip available is determined by the tire's 4 contact patches alone and not how many wheels are being driven by the engine.
You have to be very careful.... I've seen a few instances where drivers are fooled into thinking they can go faster because they have AWD. And part of this comes from a sense of 'superior acceleration' you get with an AWD/4WD vehicle. It's a false sense of security that sadly some don't find out until they go off the road, run a stop sign, or worse...Nick 568 wrote:My stance on AWD vs FWD...AWD allows you to go faster basically. Faster up to speed from a stop, faster through a corner, etc. (not denying it doesn't help avoiding getting stuck, that's true too)
Not that much faster than a FWD vehicle since they are much better in the snow than a RWD vehicle, but still faster all-around in the snow with more control.
I'm not downplaying AWD. I'm just saying that FWD is not so bad.paulvanharte wrote:Funny how people who have FWD seem to downplay AWD.
I think you misread us or we did not express ourselves correctly.paulvanharte wrote:Funny how people who have FWD seem to downplay AWD.
Yes it is better to have an AWD car than any other (as long as it is a real AWD system which is far from being the case for numbers of car manufacturers).Pescakl1 wrote: Of course, it is better to drive a Subaru during or after a snow storm, but it is a necessity? Not in my mind.
That is why I choose FWD, it helps me keep my Idiot level to a manageable levelpaulvanharte wrote:There are too many idiots on the road regardless whether they drive FWD or AWD.
