Holy crap! Btw, what is the turbo off of?sunnys14 wrote: 235/40/18 stretched on a 18x10 rim
Modified by sunnys14 at 7:31 PM 2/6/2009
Im running an Enthalpy ECU still. I want to get Nistune or Calum and tune myself because when I upgrade again, I dont wanna get left out in the cold again but Enthalpy. You are using a 38mm wastegate am I correct?eazye2000 wrote:That's good news considering I have the same turbo. Only difference is that I TIG'd on an external gate.I expect faster numbers once you get it dialed in. I was running 12.5-12.6 e/t's with my GT2860RS once I got it in the zone. 113-116mph. And that was with 225/45/17 on a 7" wheel.I've not messed with my 3076 due to weather and such. I have been learning to tune though in the meantime. So I've got high hopes for the spring. Also buttoned up some intercooler leaks and stuff too.I've cranked my 3076 up to the neighborhood of 26psi so far. That's why I had some coupler issues.. Ran pretty darn good with the exception of not knowing any solid numbers.What are you running for an ECU? Wanna check out some BIN's I've been working on?
With an 8.7 your at about a 13.5 quarter mile time.jeff420 wrote:congrats. ive never ran a 1/4 mile track before only 1/8th. my best 1/8th is 8.6 or 8.7 on a stock ka with a 75 shot. so that means in the 1/4 id get a high 12 to mid 13 comparing to your numbers.
I would like to see some BIN'seazye2000 wrote:That's good news considering I have the same turbo. Only difference is that I TIG'd on an external gate.I expect faster numbers once you get it dialed in. I was running 12.5-12.6 e/t's with my GT2860RS once I got it in the zone. 113-116mph. And that was with 225/45/17 on a 7" wheel.I've not messed with my 3076 due to weather and such. I have been learning to tune though in the meantime. So I've got high hopes for the spring. Also buttoned up some intercooler leaks and stuff too.I've cranked my 3076 up to the neighborhood of 26psi so far. That's why I had some coupler issues.. Ran pretty darn good with the exception of not knowing any solid numbers.What are you running for an ECU? Wanna check out some BIN's I've been working on?
I'd also be alot faster with a T3 manifold also (twin scroll?)WDRacing wrote:Thats awsome man You'd be SO much faster without those HUGE wheels and tires man. With drag radials I bet you'd seriously knock off a full second. Time to spring for a set of Summit 15/8 alum wheels and some 275-60's at about 20 psi
which shop you going to and how much they charging?sunnys14 wrote:Dyno sheet coming soon this friday.
I will be dynoing on a mustang dyno, it should let me know how much power I am putting down. It might read a little lower than what you guys would expect but oh well
Ofcourse cam gears would help to squeeze out more power out of these cams. At this point, I'm thinking T3 flange would help, but I am not sure how much more (I haven't dyno'd yet).Logan76 wrote:do you think that adjustable cam gears and degree'ing your cams would help you out at all? possibly going to a T3 flange also?
