My car's gonna bottom out if I install those no??theoctopussi wrote:that's how small my coilovers for my 2000 alt were...
like check this pic out:
I emailed the seller, we'll see what he has to say
They may compress a little but they definitely don't cut to have of their height under normal load.theoctopussi wrote:looked JUST like mine LOL have you seen your springs while on tho? they're squished! lol
Racingline wrote: You really really need stiffer, SHORTER shocks and struts to use these to their full potential (neither exist for the AC as of yet). Without them the car WILL bounce and even cause chattering noises when the upper spring perch becomes disconnected from the spring itself, as the spring supplied with these types of kits are usually only 8" tall uncompressed. If you really want to dump the car buy a real set of coilovers that include a shortened strut to compensate for the shorter springs.
So basically what you're saying is I can't install those on the altimaRacingline wrote: You really really need stiffer, SHORTER shocks and struts to use these to their full potential (neither exist for the AC as of yet). Without them the car WILL bounce and even cause chattering noises when the upper spring perch becomes disconnected from the spring itself, as the spring supplied with these types of kits are usually only 8" tall uncompressed.If you really want to dump the car buy a real set of coilovers that include a shortened strut to compensate for the shorter springs.
can you post up some picsjaxCoupe08 wrote:I installed ground control coilovers on my altima off my accord. Im using there usual stock ride spring rates and it does feel the same. Just to let you know all coilover springs are about the same sizes. Its just the rates are different but anyways. The rear your going have to cut a rubber boot cup which the spring will fit in. Just cut the cup so it can go lower. The front, I couldnt use the sleeves. The coil springs are almost as tall as the oem springs. Altima coupe oem springs are very short. I got about a 2-2.5" drop.
