ArizonaG35 wrote:BTW: Where the hell is Gwoods on this thread? He's usually right on top of the 1/4 mile posts... Dave
I'm here AZG35 just watching.
Kenrik wrote:Estimate this for me..
2003 G35 Coupe 6mt - Stock is 14.2 @ 101 with a 0-60 of 5.7 - 6 Seconds (Tested by Car & Driver)
My setup is as follows:
Tein S-Tech SpringsBlox 5/8th Intake SpacerZ-TubeGrounding KitEngine Damper
18x8.5 245/40/18 Front18x9.5 275/40/18 Rear
No spare tire and 40 LBS of net front seat weight removed. (replaced with a lightweight R34 GTR seat)
Times would be at 10ft above sea level (Florida) and 70 degrees temp.
Mid 13s ? 0-60 in 5.5?
take a swing at it. I'm thinking of taking it to the track to find out for sure.
Florida has an amazing DA during the spring since it it below sea level in a lot of places so if its not too hot or humid your going to run fast. Mid 13's are possible in Florida.
TeflonG35 wrote:I just looked at my car today....my fan is mechanically driven...Gay... I may ask for your help later.
You should think about a junkyard fan from a Mercury Sable/ Ford Taurus station wagon the 3.1 v6. This fan has two speeds... speed 1 is about 2100 cfm speed 2 is 4000-4500 cfm depending on the year and condition of your fan. You belt driven clutch fan probably moves in the neighborhood of 3000-3300 cfm.
I put one of these fans on my Hemi ram and the difference was amazing.
You need to use relay's. Using an amp meter find a spot in your fuse box that is powered by the ignition switch. Use it for the keyed side of both relays. For the low side of the fan use a 30 amp relay and a 30 amp fuse. For the high side of the relay use a 80 amp relay (on start up this fan can draw 100 amps!) and a 100 amp fuse (they are hard to find check radio shack). Use gauge 4 wire for the 80amp high side and gauge 14 wire for the 30 amp low side. I used a thermostatic switch to control my high side of the fan. I could also use this switch to start the fan with the motor off. the switch was mounted on top of the radiator. For the low side it came on with the ignition.
Let me know if you need any help. I will try to draw a wiring diagram for you this weekend and find some pictures of my set up.
