240HO wrote:im still wandering how u can rev that thing to 7000 rpms. are u running some kind of stand alone ems. because im runnin a stock ecu and the rev limiter comes on at 6300 and i have a 5spd. u said u did this on an automatic thats crazy.
I am not a %100, but I believe the automatic revs higher than the manual. The automatic doesnt use the computer to limit the revs during regular driving, it has a seperate device that tells the transmission when to shift.I say that I am not sure because I can not remember who was talking about it or when/where I read about it. It makes since to me because my father had a Bronco II that I drove until I was able to purchase another car. It had problems shifting(wouldnt downshift properly, it would carry out gears too long, etc..) and there was some kind of little module(it was ran off of vacuum) that told the transmission when to shift that was bad and had to be replaced.
Do a search, someone has to talk about it on here somewhere.
I found the post...
95lstegman wrote:well, if you have an automatic transmission, you probably have an ECU and a TCU (transmission control unit). the TCU controls the shift logic, while the ECU controls the engine's response to your right foot, among other things..............
Modified by zippitta at 10:21 PM 11/24/2005
