1/4 mile
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
i pulled that transmission out before i ate yesterday. i have one with 61,000 miles going in, ive been preparing for this for six months
i blew a spring out of the clutch hub, and that was keeping the clutch was disengaging, aka clutchless shifiting. i'm pissed the clutch blew up before the transmission did though, its had blown synchros for two years now, maybe more
so upon the advice of a thread on here i bought an XTD stage 3 off of ebay yesterday. 161.00 shipped, not too shabby, i'm not excited about changing it in 15k miles, but i know i'll blow something else up before then
dickie
Car: Killer Turtle
you should do a writeup on the install, i trust your knowledge more than i trust a diy that i googled
240HO
Car: 1995 240sx
yes dj i have an s14 with manual. and i also ran a 10 flat @70mph in the 1/8 with no weight reduction spare tire in trunk still haha.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
for the clutch? or transmission pulling, cuz i definately did that the wrong way.
the wrong way to pull a transmission:
step onepull motor
step twounbolt driveshaft in the middle (does nothing helpful at this point)
step threeunbolt and disconnect everything else and support, remove broken exhaust hanger. this is the step you cut yourself on the heatshield really bad, but you dont notice until you find drops of blood ALL over the garage floor
step fourpull transmission forward off the driveshaft and all the way into the engine bay
step fivechuckle like a D-Bag as you notice the hilerity of having your transmission in the engine bay (stupid fwd cars)
step sixstand on your antiroll bar and try to pick the transmission up without falling off your greasy, greasy stabilizer
step sevenhurt your back as you muscle the transmission up and out of the engine bay, then clean up all the transmission fluid you spilled everywhere.
step eighteat turkey, get drunk, pass out on fouton, have back pain
see, bam, the wrong way to pull a transmission. although i know you meant clutch
dickie
Car: Killer Turtle
thanks dude, i happen to have lots of leftover turkey and beer, are there any other special tools i should buy?
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
no, you shouldnt pull the motor to do it, and you should get the car as high up in the air as you can. you only need a 14mm and i think a 17mm. the ***** is disconnecting the transmission sensors, and just disconnect the speed sensor at the harness
i had a jack on the front of the transmission and a jackstand on the rear of the transmission, then i would put it on the ground and pull it out from under the car. oh and drain the transmission first. pulling the driveshaft out of the transmission is really hard if you have the motor in the car. but unless youre like me and you need to pull the motor, i wouldnt, although the transmission bolts are a ***** to get to without pulling upper intake manifold off
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
my 93 se coupe manual limits me at about 7200 and still pulls hard all the way up there, maybe the stage 3 clutch and fidanza flywheel help out just my 2 cents
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
i always wonder how people get their manuals to 7200, is it an auto ecu?
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
good point, i forgot to mention the guy i bought it from did a manual swap, i'll ask next time i talk to him
