oz240red »
https://forums.nicoclub.com/oz240red-u97606.html
Wed Feb 11, 2009 3:44 am
So I just reached 1,000 miles on the odometer since I put the turbo on my KA. I cranked the car with the turbo at 117,005 miles, and this morning after my ride to work I just clocked 118,086.
Just wanted to share a couple of things for those who are contemplating going KA-T with the FMU.
I went with the top mount T3/T4 setup and love it so far. This setup is good if you drive long miles to work, like me. You can easily stay off boost and save gas in any gear and when you want to wake up the car just down shift and the turbo will happily kick in. NOTE: too happy for a stock clutch (that is if you haven't changed it in a while, if you have, it might hold for some time).
With the FMU, if you run 3 inch exhaust, you will have back fire.Do the Walbro fuel pump upgrade with only half tank, like it's been said several times, you'll be thankful. (and disconnect the battery or remove the fuse before you start).
Whatever you do, heat-wrap your manifold and dp before you install them. Yes, it is highly recommended because of the heat the turbo gives out. It is the best $40 spent. Also, if you can, get the turbo blanket, that covers turbine side of the turbo.
If your turbo kit dumps the exhaust air from the wastegate to the atmosphere, buy a flex pipe and have a muffler shop route it into the downpipe or j-pipe. After boosting and letting off, you will smell unburned gasoline because the FMU raises the pressure and causes rich conditions. Its better for these gases to go out the back.
When you have the stock MAF and your BOV is not re-routed to the intake pipe just before the turbo and after the MAF, the car will stall after you accelerate hard and then suddenly brake.
Always fill up with the best gas (yes, your car will become picky and will only want to drink premium)
Get a boost gauge for sure. This saved me from popping my engine. My wastegate bolts were coming loose and it was leaking pressure by the gasket, so it was not opening at 7 psi, but around 10. If it wasn't because of the boost gauge I could have never known. Which brings me to the next point, if your turbo kit brings regular bolts for the wastegate, since this is a heavy part and goes usually tilted downwards, the vibration of the engine can cause it to become loose and cause boost creep. Go to the autoparts and get longer bolts with the same thread, and get acouple of nuts and washers. Install the bolts and put the nuts on the other side.
Very important: if you live with your woman, let her drive it and feel the power, and don't tell her how to drive it, just let her be... trust me. It's the only way she won't get on your behind for spending $$ on the parts.
Overall, the car feels great. And its FUN! From start of the project to present I have found all the info I needed on NICO. So thanks to everyone who has posted their ideas (hey, where'd the beer icon go?)
