Nope I took the front dome lights off and there is a computer (hard drive) like a flat IDE style set of wires will not work.ryanw wrote:When I had my accord I just tapped into the dome lights so the lights only came on when the doors were open. Tapping in to the glovebox would be fine for constant on lights, although I think that would be distracting while driving. I plan to eventually do the same (taping into the dome light) with my Rogue.
From the illuminating Kick Plates post you are not tapping the wires from the glove box, it is from the Body Control Module (BCM) unit, which is behind the glove box. I don't know which wire are hot or if the black is a ground, I just went by Nissan's directions that come with the kick plates. There probably is a doc somewhere that tells what each of the wires in the BCM are.Jerry98vert wrote:I have been wanting to add LED lighting under the dash and now I have seen 2 posts that looks like it can happen:
zengshengliu shows this picture: [url="11rogue-sv-pioneer-avh-p3400bh-t562674.html"]
Then I see the topic about illuminating Kick Plates where you tap into the glove box: [illuminating-kick-plates-t563663.html"]
The Kick Plates has 3 wires and the LED has 2 wires (i believe) so one wire is the DARK GREEN maybe hot and BLACK ground?
I'm stupid can't figue out the links part, any help would be great thanks.
