sure, welcome to the forum by the way!Asian wrote:Sorry I am new the the forum and don't know how to post pictures... Can you help me out and I can post one...
My pleasure Papa. I'm not a mechanic by any means either, just about everything I have learned is from this forum, so any chance I can give back...Papa_J_Smash wrote:Those look better than any online store can make them look! I asked about this in another thread and this is perfect. Extra credit for also including the piece about the in cabin filter. I'm sure I would have had that question down the road. Thanks darylzero for the play by play.
I'm not a mechanic by any means, but I can handle just about anything if I prepare for it. Does not look to be too difficult, but I HATE interior molding and clips. I had issues on a previous vehicle where the clips the kept snapping. Any danger of that happening here? Or are the clips more durable?
I can't help you there, I don't know know what kind of voltage the kick plates pull. Doing something like that is wayyyy to advanced for me.tdhk wrote:Looks good. Thanks for the tut! I was planning on illuminating my footwells as well as the rear w/ LED strips. Would I be able to just tap the wires used by the kickPlate at the bcm? I also wanted to run a 3way switch (spdt?) so that I can manually have them on at will as well. Possible ?
darylzero wrote:I went ahead and got the illuminated kick plates and have to say I'm glad I did, it is pretty sweet.
Really wasn't too hard to install, took about 1 1/2 - 2 hours. The directions really walk you through everything.
So here is the beginning by taking off the body molding.
Next you take off the molding to the left of the brake pedal. It has one screw you take off and then pull toward the brake as there is one snap at the bottom. Everything seems to just snap on and off in the car.
Next you take off the molding on the side of the console, if you have changed your in cabin filter you know how this works. Just pull toward the door and it unsnaps. The top left circle is where your in cabin air filter is located. The other red circle is where you will be routing the kick plate wire.
Next go over to the passenger side and start removing the glove box. There are seven screws don't forget the two at the top of the glove box.
Glove box removed.
I didn't get a pic of the BCM unit before I unscrewed it but it is just held in place by 4 Phillips screws. Here it is twisted and turned so that you can work on it.
Here is the tap attached to the first one, the dark green wire. You will be given 3 taps with the kick plates.
Here is all 3 wires tapped. Oh yeah they tell you to unplug the negative wire on the battery prior to installation.
After the wires are tapped you will run the cable down the side of the passenger side and zip tie it along the right edge. Here is the wire on the floor after being tapped and tied along the side of the car. The wire is laying on the floor with the carpet pulled off.
Here is the other end of the cable after routing it on the floor under the carpet through the center console.
Now I hooked the battery back up to make sure it all worked before I buttoned everything up and all was good. I thought they would have the wire from the kick plate go though a hole in the body of the car, but you actually have the 2 small wires go over the metal lip where the rubber seal goes. So the rubber seal just gets put right on top of the wires.
You will not feel the wire under the carpet, they also give you some foam tape to hold the wire down under the carpet.
The only problem I ran into was getting the screws back in the glove box one of them just did not want to go back in
Lights!
Anyone know where I can get this kind of connector? I installed mine too and love those connector. They are solid unlike the regular wire tapper which might get lose.darylzero wrote:![]()
They are called Posi-Tap, made by http://www.posi-lock.comzengshengliu wrote:
Thank you very much.sprocket wrote:They are called Posi-Tap, made by http://www.posi-lock.comzengshengliu wrote: Anyone know where I can get this kind of connector? I installed mine too and love those connector. They are solid unlike the regular wire tapper which might get lose.
They are color coded based on wire gauge size range, you need to use the correct one suited to your wire gauge.
Amazon sells them in a variety pack (link below) but you can also buy packs specific to the gauge you need, just search for them.
http://www.amazon.com/Posi-Tap-Connecto ... 009RPDOAM/
