kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Fri Aug 17, 2012 1:03 pm
Hi everyone, this is a known issue with us at the Rogue forum (We share the 2.5QR engine and identical CVT). The solution for the overheating CVT going in to limp mode (has only happened in very hot weather conditions), has been to drain a small amount of the CVT fluid. I know it sounds very strange, I couldn't believe this at first either, but from those who have had this service performed by the dealer, they all report that the problem hasn't repeated itself. Apparently the extreme heat has pushed this CVT outside of its tolerances in some cases. Remember that 2008 CVT is an early model, and I have documentation that there have been 2 to 3 minor changes to the original early 2008 CVT found in the Rogue and Altima.
Regarding the "whirring" noise from the CVT during long, hot highway trips, my 2008 Rogue makes this noise with only 50,000 km, and many other Rogue owners report the same. Most who have reported this issue have had limited success with getting help from Nissan, one or two have reported getting replacement CVT's from proactive dealerships. After extensive discussions we have all concluded that the noise is not something to get overly excited about just yet, we have many owners who have had the noise for thousands of miles and it has not gotten any worse, and th driveabilty has never suffered, fuel efficiency and performance remains high. I wouldn't worry unless you notice a difference in performance or fuel economy. We have many 08-09 owners with high miles, one in particular just hit 300,000 km with his original CVT, no repairs or major maintenance required, and he reports everything runs almost like the day he purchased the car! So my point is, this powertrain appears to be very durable, the early 08 CVT may have an issue with hydraulic noise or noise resulting from slightly uneven wear, but it does not appear to affect reliabilty or durability. I have had basically zero complaints of this vehicle leaving someone stranded with a castrophic failur in about 4.5 years on this forum since the first model year 2008.
I would recommend that you mention to your dealer the fix for hot weather CVT limp mode as advised by Nissan Tech Support at other dealerships, which is to drain some CVT fluid to lower the level. If they check with Nissan Tech support they should get this recommendation from Nissan. Good luck!
