So my mechanic had an emergency and didn't work on it for 3 weeks
. The service manual shows that the solenoid swap for a pair is only 0.9hrs, which seems incorrect like they forgot the VK45 has clearance issues that block the passenger side solenoid from being a simple swap and require the whole cover plate to be removed with the gasket scrapped /replaced.
I guess at this point I should take it to a dealer, ask them to swap it at that rate? for 1hr of labor and $200-300ish for the part?
It looked like it was burning excess oil originally, but didn't seem to be after a fill on level ground. There was significant blue smoke and rattling for a short while on startup since it'd been sitting idle at the mechanic's lot. It went back to running smoothly after warming up.
Mechanic was worried about the solenoid swap not helping, since the Snap-on diagnostic showed the degrees on that bank being 20-30 off and thought it could be a timing chain stretch and might indicate a new engine. The car has been babied and not driven hard - it had followed the premium maintenance plan religiously up until the oil getting a little low earlier this year when someone was in the hospital and it was parked on a hill and as soon as the light went on it was fixed. We weren't sure if a used engine swap would actually be worthwhile versus fixing the timing chain / gallery gasket.
What criteria would y'all use to determine a timing chain / gallery fix vs engine swap. Ours has 164k miles on it, with new cats, manifold, head gaskets around 110k miles.
