I had another engine replacement project and got it running. On Friday evening, I cruise around the neighborhood to warm the engine then slide back into my garage. I turn the car off by button, shut the door and then I open it again to do something in the car. It's at this point I realize the button is dead. Again, this car has been running for a considerable amount of time.
I still have some parts from my part out which I swapped in in different combinations. They were all working when the other car was parted out so I figured I would use this for troubleshooting.
- iKey module
- key fob slot
- push button
- BCM
- ECU or ECM
- IPDM
- Gauge cluster and the PDU behind it
- keyless entry module
- I have checked all the relevant fuses and relays (driver kick panel & around battery)
- Battery is good and up to that moment on Friday it had started the car predictably at the first attempt every single time.
- The remote function of the fob still works to open the doors, windows and trunk.
- Headlights/horn etc seem to be OK
The car still won't respond. When I insert the wrong key fob, it will have a little delay but eventually say KEY ID : NO, as expected
The security light on the dash (by the climate control buttons) keeps blinking
So, here is what stumps me. After changing the key slot, start button, intelligent/ smart key module, BCM, ECM, IPDM and the key itself; I am in effect running a different car. In my mind, this should just behave like a car that has been sitting off for a while, right?
Otherwise, replacing just the iKey requires re-registering the key fob. And when I change all the electronics from the donor car, the car gives me the same icon and is unresponsive; which tells me that yes, the car is actually seeing the components as a new car but there is another angle to the issue that I'm missing
I have sifted through the threads I found most relevant, and will post them below, although my symptoms are slightly different:
1. topic617547.html
2. post6735348.html
And of course, the FSM:
http://www.nicoclub.com/service-manual? ... M45-M35/bl
