06 M35x audio off, unresponsive
PNY50guy
Car: 2006 Infiniti M35x
2010 Infiniti QX56 4x4
Hello all,
I have an 06 M35x and my car's audio system is totally unresponsive!! I searched on here and it seems that there was no solution found. Anyways, so here's what I've done up to now:
-Ran the self diagnostics mode and found that the "audio unit" is non-existent.
-Looked at the AV section of the FSM to troubleshoot the issue.
-Ruled out the amp because I can still get navigation alert sounds.
-Tried changing out the head unit, multifunction switch and the NAVI control unit with good working parts, problem still persists.
So, now I'm my head against the wall trying to figure this out!! Is there anyone currently here who encountered this issue either currently or in the past that can point me in the right direction?? I would greatly appreciate it!!!
PNY50guy
One more thing: I did check all related fuses and they're still good.
midnightclub619
Car: 2007 Infiniti M35x
you've swapped out the entire HU and still had the same issue? Screen still works fine? NAV still operating as expected?
PNY50guy
Screen still works and no issues with the NAV
midnightclub619
In order to remove the HU you have to unplug, I think its 3 or 4 connectors, those are all plugged back in? Or does one of them look loose, damaged or old?
PNY50guy
All of the connectors looked good... All plugged in nice and tight
PNY50guy
Is it possible that both the HU and NAVI control unit is married to the BCM??
midnightclub619
that is a possibility.. looking at the FSM I didn't see the correlation but maybe i'm not seeing it...
http://pdf.textfiles.com/manuals/AUTOMO ... 35/bcs.pdf
Have you recently installed an aftermarket LOC or amp?
PNY50guy
No, it's all factory
midnightclub619
when you do the self diag what errors do you get? i see a few different ones in the FSM that you could generate
PNY50guy
It shows no errors, weirdly, and that is what's frustrating me most
EdBwoy
Do you by chance have the rear reclining seats?
PNY50guy
Yes, I do have the reclining rear seats
EdBwoy
You most likely have an electrical issue, and your rear armrest might be triggering the symptom you reported.
Here are some discussions on the matter:
1. rear-power-seat-switch-illumination-pro ... 88834.html
2. no-audio-when-rear-armrest-is-down-09-m35x-t617766.html
PNY50guy
I'll definitely check those out
midnightclub619
:bigthumb: thx Ed. never knew about those discussions.
hopefully that helps PNY
PNY50guy
So... Turns out that I had mattd860's exact issue ("the "no audio when armrest is down" link)... A broken wire!!!! Gonna fix it up and hopefully that should do it.
PNY50guy
Got it fixed now!!!!
midnightclub619
Nice! kinda crazy that the armrest would impact the HU. Enjoy your radio again :dblthumb:
PNY50guy
Yeah, it is crazy!! I would never have thought of that in a million years if it wasn't for Ed and his help!! BTW, thanks, Ed!!!
Larz
Car: 2019 Q70-L RWD
PNY50guy wrote:
Fri Feb 28, 2020 12:53 pm
I am having that same issue. I can't find a DIY on the fix though. Do you know of any? Can you share how and what you removed to locate the wire that failed?
