debiniarthug »
https://forums.nicoclub.com/debiniarthug-u137573.html
Wed Aug 03, 2011 6:07 am
I purchased my 2006 M35 in January of 2008 (the car has been on the road since November of 2005) I currently have 128,000 miles on it. I have reduced my driving significantly due to work needs in 2009. I normally drive about 30,000 miles a year.
Things that have gone wrong: As of 01/2010
Left Low beam HID headlight out - Normal I guess
Dealer: $180 - bulb $100 install, Self: $60 - bulb $0 install, 2 hrs of work
Rattling heat shield - my fault, reversing too fast down the drive way
Dealer: $330 - shield $200 install, Self: $0 tack wield crack 5 mins of work
1 exhaust tip fell off- my fault, reversing too fast down the drive way
Dealer: $??? still not replaced
Driver seat off rails - Manufacturing issue
Dealer: $1200-1500. Screw that I'll live with it
Replace brakes and tires yearly - Normal I Drive 25-30k miles a year
Dealer $350 brakes, $1,300 tires both installed Self: Brakes $78 Tires $1K
Fog light covers cracked - normal when rocks hit the covers at over 120mph
Dealer: ??? Still not fixed
Center Arm rest sliding machanisum broken - Normal at 128,000 miles
Dealer: $350 for replacement, Self: $0 Super glue and 1 hour of work
Front cup holder flap wont stay down - Normal
Dealer:??? Still not fixed but is REALLY starting to get on my nerves
Changed front rotors - Normal
Dealer: $600, Self $340 (two rotors + Pads )parts, 1.5 hours of work
Maintanence
2008 Flushed all fluids, transmission, engine coolant, brake, etc
Synthetic oil changes every 5,000 miles
2010 I gotta change my sparkplugs soon, Don't know what it'll cost me yet.
and flush the fluids
Out of the things that went wrong all was normal except one.
I hope this helps Mr Bill and everyone else who wants to know what to expect at $130K miles.
Maintenance issues: As of 08/2011
1 of 4 TPMS monitors have stoped functioning - Normal
Dealers quote: $450, Self $140 - Parts $98, labor $50
Changed rear rotors
Dealers quote: $540, Self $240 - Parts $160, Labor $80
Thermostate malfunctioned
Dealers quote: $390, Self $167 - Parts $37, Labor $130 - Normal
Dealer: ??? Fixed, manipulated the spring system, 30 min of my time
CD player stopped working - not normal, I barely used the thing in 5 years
Dealers quoute: $675, Self - I haven't fixed it, I use my EVO for music
Dash and steering wheel buttons have started to peel. - Normal
Dealers quote: $???
Yesterday - Crankshaft sensor malfuntion
Dealers Quote:$298, Self $181 - Parts $141 Labor $40
Maintentance -
Tires - Dealers quote: $1,500, Self $950 Parts and Labor included
Rear differential - Dealer $278, Self $159 - Parts $84 Labor $75
Spark plugs - Dealer $504, Self $264 - Parts $120 Labor $150
Engine Flush - Dealer $140, Self $59 - Parts and Labor included
All Belts - Dealer $450, Self $178 - Parts $98 Labor $80
Brakes F&R Dealer $620, Self $270 - Parts $170 Labor $100
BTW: All Parts are OEM, labor means I paid my mechanic, hours mean I did it myself.
I hope this helps with what you should expected at 164,042 Miles
Maintenance Issues: As of February 2012 @ 17?,000 Miles
Headlight (left & right) Ballast Malfunctioned - abnormal
-Dealer$1,800 ($600 ea. and $600 labor), Self $70 Parts, 2 hour install
Rotors and install (2 Rear) - Dealer $580, Self $180 Parts & Mechanics labor included
Brake Pads (Front) - Dealer $380, Self $60 Parts - $80 Mechanics Labor
Maintenance Issues: As of February 2013 @ 190,002 Miles
Steering wheel radio buttons rubber is detaching. Must replace soon. Might be hard to re-install due to lack of adhering and adhesion points
Radiator cracked in October before subfreezing temperatures
Radiator - Dealer$???(I could only imagine), Self $440 Parts and Labor
Moon roof lining between the glass and retractable insert was detaching causing a weird whistle when driving with the roof open.
-Dealer ???, Self $4 Parts (Are-sol garment adhesive, Painting tape)
Oil consumption - I've notice a negotiable amount of oil consumption but not enough to be concerned.
Maintenance
Four new Tires (Mount, Balance, Alignment) - Dealer $1,200, Self $900
Brake Pads and Install (Rear) - Dealer $320, Self $40 - Parts $80 Mechanics Labor
I hope this serves as a guide detailing what to expect of your M's at 190,000 Miles May your machines be as worry free as mine.
debiniarthug on Sun Feb 17, 2013 5:21 am, edited 2 times in total.
