PoorManQ45 »
https://forums.nicoclub.com/poormanq45-u17729.html
Tue Jan 19, 2010 5:06 pm
Well, just took the carbs off the bike for the third time!
The first two times I only cleaned what the walkthrough said. This ended up with no fuel going to the bowls.
So, I took them off and just started pushed, blowing, sliding, moving everything and feeling for resistance.
I found that the bladders/diaphragms were sticking and not creating vacuum. This in turn doesn't allow fuel to flow from the gas tank as there is a vacuum actuated petcock on it.
So, cleaned it all up and put everything together.
The bike fired right up once I manually filled the bowls for the first start. Oh, and a shot of ether helped
Unfortunately it is hunting for idle still. I had to dump the gas tank again as I had left about half a gallon of 6 month old gas in it when I added 2 gallons of fresh fuel.
Changed it for fresh 93 octane. Can someone please explain why the manual and everyone recommends 87 octane in this engine? The compression ratio is 12.4:1. My quad at 11.7:1 will detonate with 87...
Anyways, the new gas calmed down the idle alot. It will idle, but if you punch the throttle then let off completely it will sputter and die. I set the idle to maximum, but this didn't change anything.
So, tomorrow I am going to change the spark plugs.
Any other suggestions?
Oh, it rides nice, but the throttle isn't responding quickly IMO. This is what leads me to believe the spark plugs may be fouled.
