EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.html
Fri Apr 08, 2016 10:56 pm
I really wish the OP in that thread had updated us on how it went.
Looking at the parts catalog, the left and right solenoids have part #s 23796ZE00D and 23796ZE01C respectively, and those part numbers are used extensively in a lot of other Nissan V8 engines, no difference between the 06 and 08 engines. I am not sure why the solenoids would be different between the engines the OP had. If memory serves me right, the parts could be updated, but the part numbers usually change as well and will indicate what is being superseded.
Not sure exactly what is going on with that engine. If you feel brave enough, buy it and just reuse your current solenoids.
In the thread where you wanted to know the best way to remove an M45 engine, you mentioned that you had located an engine in the US. Is this eBay item the engine you were referring to?
