My ECU refuses to clear P1140 / P0505 DTC's that have been repaired.
1st step...(P1140) bought two new cam sensors from the dealer and installed them. Tried to clear DTC's with
Snap On's $6500 scanner...clears DTC's...and then seconds later, MIL light comes right back on.
2nd step...Checked both sensors for functionality...ground / pos 14.4V / 30Hz sine waves on both center pins...
R/R'ed both cam solenoids...cleaned / toggled them with 14.4v...BOTH work fine.
3rd step...checked for cam sensor signals directly at the ECU pins (B1- pin 73 / B2 - pin 74)...BOTH pins getting
30Hz sinewave...P1140 DTC WON'T STAY CLEARED FROM ECU.
4th step...swapped cam sensors with TWO more new ones from dealer...BOTH work fine, all voltages / signals
checked at ECU again...pins 73 and 74 both getting signals...P1140 DTC RETURNS INSTANTLY.
5th step...swapped B1's signal wire at ECU pin-73 to B2's place at pin 74...
swapped B2's signal wire at ECU pin 74 to B1's place at pin 73...
THE DTC FAULT SHOULD HAVE MOVED TO B2 AND CALLED FOR A NEW DTC P114x (IT DIDN'T)
...it still says fault P1140?!?
LET'S KEEP IN MIND THE CAR WORKS BEAUTIFULLY! There's no irratic idle, no power loss, or
"safe mode behaviors". Nothing's wrong with the car, BUT it won't clear the P1140 DTC!?!
6th step...I tried clearing the DTC's using the FSM procedure...
key on - wait 3 sec /
stomp pedal 5 times within 5 sec /
wait 7 sec /
press and hold down pedal 10 sec or longer /
it clears the DTC's / AND MIL LIGHT COMES RIGHT BACK ON?!?
P0505 DTC: I replaced the whole airbox and snorkel up to the throttle body with a high dollar aftermarket intake
system...sprayed the whole thing down with carb cleaner while it was running to check for a change in
idle (If I had a vacuum leak the engine would've raised in RPM)...NO LEAKS!...clear the DTC's...AND BAM,
MIL LIGHT P0505!
The car is fixed, works fine, but MIL light won't stay off! I even cleared the DTC's and removed power from the ECU...I left it unplugged (no power for 72 full hours)...hook it up, start the car, and BAM-O! MIL LIGHT!
The ECU is acting like it has solid state memory like a thumb drive or test equipment.
HOW EXACTLY DO YOU CLEAR THE ECU STORAGE MEMORY IN A 2002 Q45!?! I've never, ever, heard of a modern day car (2000 yrs+) with solid state memory that won't clear with a wipe AND powerloss.
